crank gasket leak
Old Apr 18, 2013 | 01:06 PM
genik's Avatar
genik
crank gasket leak
Im having a minor leak there and i must change the gasket. Are there high quality gaskets to choose from?
Old Apr 18, 2013 | 07:25 PM
boOst spIKe's Avatar
boOst spIKe
Front crank seal or rear main seal? as for high quality replacement, OEM.
Old Apr 18, 2013 | 10:00 PM
genik's Avatar
genik
i dont really know whats the front or rear, but when lifting the car you can see it underneath
as for OEM what do you mean?
Old Apr 18, 2013 | 10:04 PM
Bakerbrdz's Avatar
Bakerbrdz
Oem=mini
Old Apr 18, 2013 | 11:20 PM
genik's Avatar
genik
why would the OEM be the best? aren't there any other brands?
Old Apr 19, 2013 | 04:15 AM
Braminator's Avatar
Braminator
Oem=mini
OEM= Original Equipment Manufacturer. Why is it better? It does not always make it better bu the OEM usually does not cut corners to make it cheaper. Thats not to say the aftermarket one is made cheaper in all cases. There are many they have improved on the OEM's part. So just buy a quality brand.
Old Apr 19, 2013 | 01:27 PM
genik's Avatar
genik
I think that crank gaskets are a pretty important spare part so ill be looking to find something better than the OEM, but what would the better -or best- quality brand for gaskets be?
Old Apr 20, 2013 | 01:02 PM
genik's Avatar
genik
this is it guys, its after a hard drive so u can see that the oil is burned there but u can see some remainings of how it was spread
Attached Thumbnails crank gasket leak-crank-gasket-00.jpg   crank gasket leak-crank-gasket-01.jpg
Old Jul 18, 2016 | 10:13 AM
perryinva's Avatar
perryinva
Old thread, but someone isnt mislead, this is not a crank seal or RMS leak, but likely the oil filter housing or turbo feed line or both.
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
weaver9000
Sep 14, 2015 05:48 PM
kjd186
Sep 9, 2015 10:02 AM
Sep 2, 2015 09:05 AM
