R50/53 limited slip differential on Mini?
Old Oct 24, 2002 | 01:18 PM
futruemini's Avatar
futruemini
I wasn't sure whether this should go in this forum or the technical forum. Do either the MC or MCS have limited slip differential or are they just standard axles? I didn't see anything on the specs on the Mini website.
Old Oct 24, 2002 | 01:37 PM
Santa's Avatar
Santa
According to the dealer literature, traction control is standard on the MCS and is part of the Dynamic Stability Control (DSC) option package for the MC.
Old Oct 24, 2002 | 02:23 PM
futruemini's Avatar
futruemini
Santa, thanks for the info but traction control isn't the same thing as limited slip differential. Traction control basically has a sensor that limits the amount of gas and even applies the brakes on a slipping tire. But only ONE tire will spin. Not to get into too much detail, but limited slip differential has a spring pack and clutches in addition to the standard differntial. Basically when one tire starts spinning faster than the other, the torque that is required to overpower the clutches will be applied to the other wheel as well (ie, both tires will then move). Best way to test this, is if one front tire is on ice and the other front tire is on pavement, will both tires get power.? If the tire on the ice just spins and spins and you don't move forward, then you don't have limited slip. Or if you are doing a burnout from a stop, do you see black marks from both front tires or just one? I don't see limited slip on too many front wheel drive cars, that's why I asked. I was just curious.
Old Oct 24, 2002 | 02:27 PM
8ball's Avatar
8ball
Check MiniMania's site ... they have LSD's available.
Old Oct 24, 2002 | 02:30 PM
Mark's Avatar
Mark
North American Motoring :: Founder
futuremini,
Neither the COOPER or COOPER S have an LSD. Quaife now has one available for the COOPER S and one of our sponsors, MINI Madness, is carrying it. You can find additional information here
Mark
futruemini's Avatar
futruemini
8Ball, So LSD (geez that sounds bad) is not standard on the Coopers?
Old Oct 24, 2002 | 02:34 PM
futruemini's Avatar
futruemini
Thanks for the info, guys!
Minimania offers a 4.54 LSD?!!! wow!
Old Oct 24, 2002 | 02:38 PM
Mark's Avatar
Mark
Be aware that the Mini Mania LSD is for the COOPER only. If you are interested in this unit be sure to contact them for additional information as I'm not sure who developed this unit.
Mark
Old Oct 25, 2002 | 03:52 AM
jlm's Avatar
jlm
i think min maddness is offering the quaife for around $1,100, but the install has been rumored to be another $1,500.
quaife has indicated they will be releasing the lsd in late october; check out their website and give them a call.
wkp1219
Nov 13, 2015 07:52 AM
joedotmac
Aug 28, 2015 01:04 PM
ASRman
Aug 13, 2015 09:33 AM
