R50/53 Broken PCV Valve
Old Apr 14, 2013 | 02:42 PM
Tab32's Avatar
Tab32
Broken PCV Valve
So I was checking the PCV valve today and I overtightened it, thus snapping it. I've gotten the broken piece out, and since the o-ring was still attatched with a little thread, I put a small amount of JB weld on it. I'm ordering a new valve tonight, but it won't be here for a week.
I'm afraid that the valve will pop off due to pressure. Do you think a bit of JB weld will be enough to hold it on for a week?
Old Apr 14, 2013 | 03:19 PM
GreekDrifter91's Avatar
GreekDrifter91
ted, you wanna show pics of how its broke? JB weld is some pretty strong stuff. im sure it will be fine for a week, even forever... seen and used it used in much worse scenarios than just holding a pcv together
you should see how my pcv is held together right now lol i have anew one just havent installed it yet
Old Apr 14, 2013 | 03:45 PM
astroBlackMetallic_Mini's Avatar
I'll sell you a used one for cheap! New they're like $30... Pm me if interested
Old Apr 14, 2013 | 03:58 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Just put the old one back in for a week.
Shouldn't make much difference in that time frame.
Old Apr 14, 2013 | 04:06 PM
Tab32's Avatar
Tab32
It's too late to take a picture since I already put the epoxy. Basically the threads snapped in half. So I have a bit of threading and the o-ring attached still.
I'm hoping I won't need to drive it like a granny until I get the replacement...
Old Apr 24, 2013 | 03:35 PM
Tab32's Avatar
Tab32
Since I didn't completely seal the PCV Valve back on, am I losing boost due to the escaping pressure? I've been feeling a lack of power lately, and i'm wondering if It's just me or not.
Old Apr 24, 2013 | 05:36 PM
ZippyNH's Avatar
ZippyNH
No boost loss...
The area is sucks gasses from is just BLOW-BY...
Gasses that escape from worn valves or rings....
in the old days it was just vented in a tube to the atmosphere....was piped to point at the ground.
As a emmisions thing, it was rerouted so the engine sucks it back in, and burns it!
So NO worries!
Old Dec 21, 2021 | 05:38 PM
Aussie R53's Avatar
Aussie R53
Same problem and same idea
Hey, I had same problem and came up with same solution. I have a 3 hour drive ahead and won’t get part in time. I’ve tried everywhere and due to Christmas can’t get the part. Fingers crossed, will post update when I Install the new one. The JB is good up to 550f
someone wanted photos of break - see attached
Old Dec 22, 2021 | 11:00 PM
Aussie R53's Avatar
Aussie R53
No good
No good. Glued it with JB. Left 24 hours. Screwed in and with almost no pressure it snapped at previous break. I have one on order but pain to get one this side of mid January
Old Dec 23, 2021 | 01:19 PM
Just found the mopar part if you in a pinch, you can go local. 4693369aa
https://www.ecstuning.com/Search/SiteSearch/4693369a/
Old Dec 23, 2021 | 04:04 PM
Aussie R53's Avatar
Aussie R53
Bush mechanic solution (short term)
Cheers for that. I had ordered one, unfortunately shipping to Australia will be early January but I am on a trip 27th Dec. I went bush mechanic with cable ties to get me through till then. The o ring gives a good seal and the suction hose presses it in place, I just need to hold it in place for one or two good drives. It looks worse than it is
Old Dec 27, 2021 | 01:03 PM
Welcome.
I approve this fix.
Old Dec 27, 2021 | 10:40 PM
mr.r50's Avatar
mr.r50
Seen this late, love the idea
elverado
Jan 18, 2022 02:51 AM
R3411y
Sep 11, 2015 03:38 PM
Sep 11, 2015 11:09 AM
kjd186
Sep 9, 2015 10:02 AM
ShadyCoop
Sep 8, 2015 04:50 PM
