R50/53 06 R53, Weird fluctuating air noise at part throttle
Old Apr 13, 2013 | 03:24 PM
nicefighter80's Avatar
nicefighter80
Hey guys, I'm having a rather weird issue.
First its a 08/06 build Cooper S, 115k miles with only mod being a DDM intake
Second it has no codes
Now what is has been doing at part throttle is like a fluctuating power/noise, you can feel almost yo-yoing. With the DDM intake I can hear the intake pulling in air, and today with the window down I heard the air go from normal sucking noise then go away then repeat all under the same part throttle. This happens at a normal rate, its not a slow process but you can clearly hear it doing something.
Another thing, I have a ultragauge set to read boost psi, and when its acting normal its reading 7.5-8.2 psi, but when it fluctuates, it drops to 5 psi and goes back up and repeats
My question, Is this a sign of the bypass valve going out? or perhaps the belt?
I'm new to mini's, If someone could shed some light, that would be great
Old Apr 13, 2013 | 04:37 PM
astroBlackMetallic_Mini's Avatar
Could be the BPV. Try resetting the ecu first, sometimes that clears up stuff like that.
Old Apr 13, 2013 | 04:52 PM
nicefighter80
I did reset it using both the battery disconnect and the reset though the trip odometer, I think it is the BPV but it seems odd with an late 06 build. Thank you for the input.
Old Apr 13, 2013 | 05:00 PM
Hmm. Well, push on the BPV spring. It's right there, you can see it. See if its soft or something
Do u have a JCW? Maybe look at the hose going to the BPV, see if there are any cracks or something.
Old Apr 13, 2013 | 05:06 PM
nicefighter80
It is not a jcw, bone stock with a DDM, I pushed on the lever to turn it and it has good tension, nothing that seemed too soft to me. I'll look at the vacuum line tomorrow. Could the IC boots be an issue?
Old Apr 14, 2013 | 06:41 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Did you first notice this after installing the CAI.
Old Apr 14, 2013 | 11:50 AM
nicefighter80
It was doing it before the CAI as well, just more noticeable now with it
Old Apr 26, 2013 | 09:50 PM
nicefighter80
Update: So today I was looking at the mini's pulley/belt and noticed I have a alta 15% SC pulley and a alta crank pulley. I had already ordered a 17% and a new bypass valve so I will have 15 alta pulley for sale if anyone is interested. When I got my new bypass valve spring felt much stiffer than the one that's on it, like my at least x4.
iggi
18
Feb 9, 2026 01:00 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
PrimePower
Aug 16, 2015 06:29 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
