R50/53 I'm at 100k and the dealer wants $230 for plugs?
Old Apr 9, 2013 | 06:08 PM
princeofwaldo's Avatar
princeofwaldo
$230 seems kind of steep, and then once they add in all the bogus misc. fees and tax will be more like $300.
How complicated can replacing them be?? Any reason I can't walk-in to O'Reilly Automotive, tell them I've got a 2006 Mini and get plugs from them? Would the gap be correct over the counter, or do plugs still require to have the gap adjusted like it was still 1946?
Thanks for any advice.
Old Apr 9, 2013 | 06:11 PM
Braminator's Avatar
Braminator
Screw that. Go get NGK 4285's these are the JCW 4 prong no gapping needed. Change them yourself.
Old Apr 9, 2013 | 06:12 PM
ZippyNH's Avatar
ZippyNH
Plugs are about $50 plus the dealer charges about $130+per hour labor....
If you DIY them, USE A TOURQUE Wrench!! Many have been spit out!!
Iridium Plugs or the OEM multi-prong does not/cannot be adjusted.
Old Apr 9, 2013 | 06:13 PM
ZippyNH's Avatar
ZippyNH
The OP does not have a pulley....so the OEM plug will be fine!!
Old Apr 9, 2013 | 06:21 PM
Braminator's Avatar
Braminator
Zippy I saw JCW in his sig. So you are correct if he does not have a pulley. My bad
Old Apr 9, 2013 | 06:31 PM
ZippyNH's Avatar
ZippyNH
Hyper Blue Silver Roof 2006 MC
heck...looked again...just a Cooper!!
Old Apr 9, 2013 | 06:33 PM
Braminator's Avatar
Braminator
I guess my old eyes are tired. Like I said I saw JCW and went with it. LOL
Old Apr 9, 2013 | 08:12 PM
miniblucabrio's Avatar
miniblucabrio
These Mini dealers are nuts! Saw an ad for a local dealer that wanted $300 to rotate, balance, inspect tires and do an alignment! Change the plugs yourself. $50 for plugs $30 for a decent torque wrench. Make sure the engine is cold when you change them though.
Old Apr 9, 2013 | 10:56 PM
ZippyNH's Avatar
ZippyNH
2006 MINI COOPER 1.6 L4 W10B16A FI
Spark Plug
Part No.
Stock No.
Plug Gap
Standard BKR6EKUB
7969
.032
V-Power BKR6E
6962
.032
G-Power BKR6EGP
7092
.032
Laser Platinum BKR6EQUP *
3199
.032
Iridium IX BKR6EIX
6418
.032
From the NGK website....for a cooper....
**plugs for an S or JCW S (or a S with a pulley are different)**
*****Note, the NGK is the OEM plug maker for the MINI*****
The stock plug is a multi prong like this
many folks do go to this style..an Iridium plug
Neither gets gapped
Old Apr 9, 2013 | 10:58 PM
ZippyNH's Avatar
ZippyNH
And like we said before, USE A TOURQUE WRENCH!!
Even a cheap Harbor freight one. Many MINI's have had plugs spit out, needing a helicoil to fix the threads. The aluminum in the head is not very forgiving!!
Old Apr 10, 2013 | 04:19 AM
ofioliti's Avatar
ofioliti
And replace them when the engine is COLD.
Old Apr 29, 2013 | 09:29 PM
spyder152's Avatar
spyder152
what's the torque spec for the spark plugs, thanks
Old Apr 29, 2013 | 09:33 PM
atraain's Avatar
atraain
Go here this might help http:// http://www.pelicanparts.com/...eplacement.htm
Old Apr 29, 2013 | 10:56 PM
BlwnAway's Avatar
BlwnAway
22 ft/lb
Old Apr 30, 2013 | 08:12 PM
spyder152's Avatar
spyder152
Originally Posted by BlwnAway
22 ft/lb
Old Apr 30, 2013 | 09:28 PM
dannyhavok's Avatar
dannyhavok
These horror stories helped me decide to split the difference... I ordered a torque wrench but it didn't arrive in time (Needed the plugs changed before a road trip.)
I bought the plugs for $40 (NGK iridiums) and the dealer was happy to install them for $70.
Old Jun 19, 2013 | 11:33 PM
omri617's Avatar
omri617
Must ask , (Tried searching didn't find answer) -
BKR6EQUP spark plugs , for the R50 , how many miles can go before being replaced?
Thanks!
09R56
Nov 16, 2022 10:49 AM
Eric Campbell
35
Oct 27, 2020 08:31 PM
madmaxxed
Aug 24, 2015 11:56 PM
Beau B
12
Aug 24, 2015 01:50 PM
