North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   R50/R53 :: Hatch Talk (2002-2006) (https://www.northamericanmotoring.com/forums/r50-r53-hatch-talk-2002-2006-8/)
-   -   R50/53 I'm at 100k and the dealer wants $230 for plugs? (https://www.northamericanmotoring.com/forums/r50-r53-hatch-talk-2002-2006/248873-im-at-100k-and-the-dealer-wants-230-for-plugs.html)
princeofwaldo Apr 9, 2013 06:08 PM
$230 seems kind of steep, and then once they add in all the bogus misc. fees and tax will be more like $300.
How complicated can replacing them be?? Any reason I can't walk-in to O'Reilly Automotive, tell them I've got a 2006 Mini and get plugs from them? Would the gap be correct over the counter, or do plugs still require to have the gap adjusted like it was still 1946?
Thanks for any advice.
Braminator Apr 9, 2013 06:11 PM
Screw that. Go get NGK 4285's these are the JCW 4 prong no gapping needed. Change them yourself.
ZippyNH Apr 9, 2013 06:12 PM
Plugs are about $50 plus the dealer charges about $130+per hour labor....
If you DIY them, USE A TOURQUE Wrench!! Many have been spit out!!
Iridium Plugs or the OEM multi-prong does not/cannot be adjusted.
ZippyNH Apr 9, 2013 06:13 PM
The OP does not have a pulley....so the OEM plug will be fine!!
Braminator Apr 9, 2013 06:21 PM
Zippy I saw JCW in his sig. So you are correct if he does not have a pulley. My bad
ZippyNH Apr 9, 2013 06:31 PM
Hyper Blue Silver Roof 2006 MC
heck...looked again...just a Cooper!!
Braminator Apr 9, 2013 06:33 PM
I guess my old eyes are tired. Like I said I saw JCW and went with it. LOL
miniblucabrio Apr 9, 2013 08:12 PM
These Mini dealers are nuts! Saw an ad for a local dealer that wanted $300 to rotate, balance, inspect tires and do an alignment! Change the plugs yourself. $50 for plugs $30 for a decent torque wrench. Make sure the engine is cold when you change them though.
ZippyNH Apr 9, 2013 10:56 PM
2006 MINI COOPER 1.6 L4 W10B16A FI
Spark Plug
Part No.
Stock No.
Plug Gap
Standard BKR6EKUB
7969
.032
V-Power BKR6E
6962
.032
G-Power BKR6EGP
7092
.032
Laser Platinum BKR6EQUP *
3199
.032
Iridium IX BKR6EIX
6418
.032
From the NGK website....for a cooper....
**plugs for an S or JCW S (or a S with a pulley are different)**
*****Note, the NGK is the OEM plug maker for the MINI*****
The stock plug is a multi prong like this
http://www.ngksparkplugs.com/images/tip/NGK3199-2.jpg
many folks do go to this style..an Iridium plug
http://www.ngksparkplugs.com/images/tip/NGK5688-2.jpg
Neither gets gapped
ZippyNH Apr 9, 2013 10:58 PM
And like we said before, USE A TOURQUE WRENCH!!
Even a cheap Harbor freight one. Many MINI's have had plugs spit out, needing a helicoil to fix the threads. The aluminum in the head is not very forgiving!!
ofioliti Apr 10, 2013 04:19 AM
And replace them when the engine is COLD.
spyder152 Apr 29, 2013 09:29 PM
what's the torque spec for the spark plugs, thanks
atraain Apr 29, 2013 09:33 PM
Go here this might help http:// http://www.pelicanparts.com/...eplacement.htm
BlwnAway Apr 29, 2013 10:56 PM
22 ft/lb
spyder152 Apr 30, 2013 08:12 PM
Originally Posted by BlwnAway (Post 3729640)
22 ft/lb
dannyhavok Apr 30, 2013 09:28 PM
These horror stories helped me decide to split the difference... I ordered a torque wrench but it didn't arrive in time (Needed the plugs changed before a road trip.)
I bought the plugs for $40 (NGK iridiums) and the dealer was happy to install them for $70.
omri617 Jun 19, 2013 11:33 PM
Must ask , (Tried searching didn't find answer) -
BKR6EQUP spark plugs , for the R50 , how many miles can go before being replaced?
Thanks!
