How do I program options?
Old Apr 6, 2013 | 04:46 PM
Beermaestro's Avatar
Beermaestro
Maybe I am inept; maybe it isn't possible. But I've read about the options that can be programmed (locking, unlocking, etc.), but cannot find out how to do it. The car is a 2006 R50. I just want to be able to turn off the 'feature' that locks the doors on take off--that kind of thing.
Did a search... couldn't find any answers. Any help?
Jack
Old Apr 6, 2013 | 04:51 PM
Braminator's Avatar
Braminator
Welcome aboard. We need pics of your MINI before we can help you out. Just kidding. Here is a link that will help you understand what needs to be done
https://www.northamericanmotoring.co...e-options.html
Old Apr 6, 2013 | 04:53 PM
Braminator's Avatar
Braminator
Also vendors Like Way Motor Works can do it for you. He will be at the dragon offering this service, contact him.
Old Apr 6, 2013 | 05:15 PM
scf's Avatar
scf
You can also get creative by reading ALOT about NCS Expert:
https://www.northamericanmotoring.co...onal-info.html
https://www.northamericanmotoring.co...de-add-in.html
https://www.northamericanmotoring.co...beginners.html
You'll need to download the files, and purchase a cable. Read thoroughly all you can, and be sure you understand what you've read, BEFORE you try anything. You can effectively kill your Mini with even a small mistake.
The locking didn't bother me, as a matter of fact I don't mind it. It was that I had to unlock the doors, or double pull the handle to get out. Turned on the autounlock when ignition off, and voila! Also did a few other things.
Old Apr 6, 2013 | 08:07 PM
rkw's Avatar
rkw
And with that, I think it's crazy to recommend NCS Expert to a MINI novice.
For a 2006, go to a dealer and ask them to update your options. They will probably charge about a half hour of labor. Some independent shops like Way Motor Works can also do the update. On newer models of MINI, many options can be directly updated by the owner, but not a 2006.
NCS Expert is essentially the computer software used by dealers to update the car's software. MINI hobbyists and enthusiasts have learned to install and use it. It requires a high degree of technical competence, and there is a very real risk of damaging your car if you do something wrong.
Old Apr 6, 2013 | 08:43 PM
scf's Avatar
scf
Likely VERY good advice. I was just answering his intended question. It's NOT for the feint of heart by any stretch of the imagination. I easily had 60-70 hours of just investigation, and research before I even ordered the cable. Held off ordering the cable because I just KNEW I'd try it before I really had even a glimmer of understanding.
Old Apr 6, 2013 | 10:17 PM
Beermaestro
Well, I appreciate the information. Obviously, I'll have a decision to make. My expertise does run to jail breaking my kindle, but I don't even own a laptop.
I come from a driver's perspective, and I find the car quite amazing without all the electronics. But I also come from a DIY way of doing things, and control over these options is something I think I ought to have.
You all make it sound like it's Mission Impossible and if I cut the wrong wire I'll never see Duluth again. Maybe so. But it would irk me extremely to have to pay someone to program the car not to lock its doors when starting out.
Old Apr 7, 2013 | 03:04 AM
scf's Avatar
scf
Without a laptop, it cannot be done. Cable for car is only 3' long.
Old Apr 7, 2013 | 08:09 AM
Beermaestro
It can't be done with one of the wifi devices? My desktop runs XP...
Old Apr 7, 2013 | 10:15 AM
Densmini's Avatar
Densmini
There are Wi-Fi plugs that go into the OBD port. However, I think they are only OBD2 specific, not enabled for the INPA/Ediabas, etc. I.e., I don't think they will work.
Old Apr 7, 2013 | 11:29 AM
rkw's Avatar
rkw
I wouldn't use anything less than a hardwire connection. If there is any timing or communications issue, the potential consequences are too serious.
Old Apr 7, 2013 | 03:56 PM
scf's Avatar
scf
Exactly.
Old Apr 7, 2013 | 05:10 PM
ZippyNH's Avatar
ZippyNH
Yup...
A bricked kindle or I-phone is one thing...
A bricked car is in another class entirely!!
Old Apr 7, 2013 | 10:56 PM
Beermaestro
Originally Posted by ZippyNH
Yup...
Okay, okay. I give up. I think. For now anyway.
Thanks to everybody who chimed in. It wasn't what I wanted to hear, but hear it I have.
Old Apr 8, 2013 | 04:17 AM
scf's Avatar
scf
Talk to you local dealer, see how much to program. Talk to any within driving distance, as they can vary in price.
Old Apr 22, 2013 | 07:07 AM
Beermaestro
I have decided to do this. I've ordered a cable:
Amazon.com: SainSpeed K+D CAN USB Interface OBD2 Cable Diagnostic Scanner for BMW only: Electronics Amazon.com: SainSpeed K+D CAN USB Interface OBD2 Cable Diagnostic Scanner for BMW only: Electronics
(can someone confirm it should work?) and I've been reading my eyes red. I must say with all due respect that some of the dire warnings are a bit over the top. If one proceeds carefully, backs up judiciously, follows carefully in the footsteps of others, I think it would be pretty hard to brick one's car.
Besides living 80 miles from the nearest MINI dealer, I want to have access to my car's programming. Simple as that. Frankly, I'll take the crowd sourcing of this community over a tech at the dealer who may or may not be expert in this stuff.
Old Apr 25, 2013 | 03:02 PM
KMalinich's Avatar
KMalinich
Check out my thread
I'm not trying to be a ****, but if you understand the thread, then you'll be fine. If there's parts you don't get, I can lend a little bit of help, but it requires a lot of technical know-how.
Old May 20, 2013 | 10:35 AM
Beermaestro
Originally Posted by KMalinich
Check out my thread
Never thought you were a *****.
Okay, got my little system up and running and this morning turned off my DRL and the autolock on startoff (hooray). But there are some other things I'd like to do and I'm having a hard time finding information specific to my car (R50). The spreadsheet seems a little scanty and it seems to be just for 2nd Gen cars. Is there somewhere a clearinghouse of programming options for 1st Gen cars?
Also, here's a list of modules I see when I read my ecu... does this look right?
ABG
BC1
EMS
EWS
KMB
MK60
RAD
RIP
SHD
Old May 20, 2013 | 02:15 PM
KMalinich's Avatar
KMalinich
ABG
BC1
EMS
EWS
KMB
MK60
RAD
RIP
SHD
Yeah, that all looks right.. Try using NCSDummy, it'll translate things for you.
The spreadsheet available is definitely for 07-up.. Most of it doesn't really correspond.
What I did (I don't really recommend this, but hey) was I used Google Translate to translate over from German to English, you can kind of get a feel for what it's trying to say
Old May 20, 2013 | 02:26 PM
Beermaestro
Yes, I'm going to have a go at Dummy. Maybe it's me, but its learning curve seems steeper than NCSexpert's.
Old May 20, 2013 | 02:56 PM
KMalinich's Avatar
KMalinich
The whole idea of NCSDummy is for it to read the file that NCSExpert creates.. And it can make the changes (in English) and write them back to the file, and then you use NCSExpert to write them to the car.
Old May 20, 2013 | 06:13 PM
Beermaestro
yeah, I had that worked out. What I'd missed was the instruction to jot down the version of the module I was modding--once I did that it all fell into place. I did a little more exploring in BC1 and got auto up on the driver's side.
Getrieben
Sep 21, 2023 03:31 PM
TREX
Nov 2, 2019 07:31 PM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
