GP2 Wheel Fitment
Old Mar 30, 2013 | 07:54 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
GP2 Wheel Fitment
Please post here on what wheels you have found to fit over the GP2 front brakes as this may make a great reference thread later.
I found my BBS RGRs 17 inch will only fit with a 10mm spacer.
Also Factory JCW R112s also require a 10mm spacer to clear.
Will be test fitting some NM wheels this coming week.
Old Mar 30, 2013 | 10:52 PM
ra2fanatic's Avatar
ra2fanatic
At least state the known/existing offset along with the spacer size. That'd be more valuable than saying just the spacers...
Old Mar 31, 2013 | 01:47 AM
robbo mcs's Avatar
robbo mcs
Just a note for anyone checking, as well as checking clearance of the brakes you also need to check clearance from the front suspension. From my experience with bilstein coilovers on my JCW some some rims will clear the brakes with 10m spacers but may need 15mm for the springs. I suspect the GP will probably be the same.
Old Mar 31, 2013 | 02:56 PM
WayMotorWorks
Vendor
The offset actually has very little to do with it, it's more about the spoke shape, and thickness that is rubbing on the calipers.
Old Mar 31, 2013 | 09:55 PM
fastminiz's Avatar
fastminiz
I would love to put on the NM RSe05 wheel on my GP. Emailed to NM about the fitment also.
Old Mar 31, 2013 | 10:18 PM
Braminator's Avatar
Braminator
Old Apr 2, 2013 | 06:45 PM
glmini's Avatar
glmini
I did not find the 10mm spacers in your calalog, do you carry them for the JCW R112 wheels.
Old Apr 2, 2013 | 08:49 PM
WayMotorWorks
Vendor
I will let you know once I get them as NM thinks they will but we'll see.
No 10mm spacers as you loose the hubcentric hub at 10mm, that is why we do 15mm to keep that.
Old Apr 5, 2013 | 03:20 PM
bananamini's Avatar
bananamini
What's the factory solution for this? I was under the impression that they shipped with JCW R112 wheels if you specified runflats.
http://www.motoringfile.com/2012/10/...-options-list/
Old Apr 6, 2013 | 04:31 PM
Airborne Ranger's Avatar
Airborne Ranger
That's the first I've heard of it. Here in Washington, I had the choice of keeping Kumho Ecsta V700 tires or swapping them out with another All-Season version of Kuhmo tires. Never heard an option of different wheels from the dealership.
Old Apr 6, 2013 | 04:36 PM
Airborne Ranger
Ok, back on track. Volk Racing TE37 17" x 7.5" +37 offset all around work great with stock Kumho's. No clearence issues whatsoever.
Old Apr 6, 2013 | 04:40 PM
Braminator's Avatar
Braminator
Very nice looking. Good luck.
Old Apr 6, 2013 | 04:43 PM
Airborne Ranger
Thank you Braminator... will also note that it is sitting at the lowest factory setting in those photos... Not low enough for my likings (particularly up front) so I will be swapping them out for H&R Coilovers on Wednesday. Stay tuned for an update.
Old Apr 6, 2013 | 04:46 PM
Braminator's Avatar
Braminator
Are you going to sell the stock CO's? I can wait to see it. I guess you have the roads that allow it to be low.
Old Apr 6, 2013 | 04:47 PM
Braminator's Avatar
Braminator
I am not a fan of the stock wheel on the GP's, so yours IMO is the best looking one so far.
Old Apr 6, 2013 | 04:50 PM
Airborne Ranger
I also am not a fan of the OEM wheels... I also have a set of 18x9 HRE's that I will be fitting this week- they are definitely more agressive- had an issue with fitting the TPMS sensors today so I have to do a little dremel surgery so they can lay flat on the barrel- those clear as well and will update with photos once I get them permenantly mounted.
Old Apr 6, 2013 | 04:54 PM
Airborne Ranger
I plan to keep them so I can switch them back to stock when the time comes. All my cars are low (minus my SUV) and I have predetermined routes everywhere I go I dont plan to dump it- but want it a little lower... would like the fronts to match the rears in my pics
Old Apr 6, 2013 | 04:56 PM
Braminator's Avatar
Braminator
Awesome. I will be following your progress. Good luck and motor on.
Old Apr 8, 2013 | 12:19 PM
WayMotorWorks
Vendor
NM fits
Just finished test fitting the NM RSe05 17inch wheels fit and clear the brakes fine.
Old Apr 8, 2013 | 12:26 PM
Braminator's Avatar
Braminator
That is one of my favorite wheels. I love the way they really show off the brakes.
Old Apr 8, 2013 | 11:12 PM
Chief_Charlie's Avatar
Chief_Charlie
Way,
Confirm you don't need a spacer with these NM Wheels?
What is the cost of the TPMS for each wheel? I didn't see them available on your site.
Last edited by Chief_Charlie; Apr 8, 2013 at 11:14 PM. Reason: additional question
Old Apr 9, 2013 | 07:15 AM
WayMotorWorks
Vendor
Originally Posted by Chief_Charlie
Way,
NO spacers needed.
As for the TPMS I need to see if these are any different as we ran into that issue before, but should be around $200
Old Apr 9, 2013 | 07:25 AM
Chief_Charlie
Thanks Way
Let me know
Old Apr 9, 2013 | 08:42 AM
andywong33's Avatar
andywong33
Way,
Would these brakes fit a regular r56 MCS directly without changing anything else major such as servos etc?
Old Apr 9, 2013 | 09:14 AM
WayMotorWorks
Vendor
Originally Posted by andywong33
Way,
yes you can put them on your reg R56, but it won't be cheap.
