Oil leak - common suspects
Old Mar 14, 2013 | 02:00 PM
thulchatt's Avatar
thulchatt
I have had a persistent oil drip. Not a lot, just one drop most days.
I did the crank position sensor o-ring last weekend and still have the drip.
I don't think it is the oil pan gasket because the sensor was covered with oil and dirt. This makes me think the leak is above the pan gasket.
So, I see two likely options:
1. Valve cover Gasket
2. I did not get a good seal with the o-ring install
Is there another oil leak option on the front of the engine?
Other thoughts?
Old Mar 14, 2013 | 02:12 PM
Posted this in another thread but it was it was very informative: Fits R50 R52 R53 models.
The valve cover gasket is not that hard. Once you unbolt everything it on the top of the engine.
We have them right here in the kit and single gasket.
http://www.ecstuning.com/Search/11121485838/
Here are the valve cover seals if you don't get the kit:
http://www.ecstuning.com/Search/11127513066/
The cam potion sensor on the rear has a little o ring. Not hard to access and replace.
Cam position sensor is number #8 , o-ring is #9
http://www.ecstuning.com/Search/12147514984/ES28615/
Where you able to check around the cam position sensor ? They are known to leak.
I would also do the valve cover. That's the number one area on the front for leaks.
Pics would help of the locations you were talking about.
JAB 67's Avatar
JAB 67
You need to tell us what model you have before we can help.
Old Mar 14, 2013 | 03:36 PM
thulchatt's Avatar
thulchatt
Good point
2004 R53, 75,000 miles
But I think this would be common to all 1st gen
Old Mar 14, 2013 | 06:38 PM
Braminator's Avatar
Braminator
Check your oil fill tube seal also. I had to replace mine once. Thought it was coming from the cranks sensor and found it to be the fill tube. http://www.autopartsnetwork.com/cata...osition:Lower_
Old Mar 18, 2013 | 08:19 AM
thulchatt's Avatar
thulchatt
Good thought and I will check, but I think this is below where I am seeing oil. The crank position sensor had oil so I don't think the oil would move up that high. But, I am often wrong.
Old Apr 25, 2013 | 07:18 AM
ih8cornnuts's Avatar
ih8cornnuts
This often forgotten part leaks on most of our minis, mine leaks oil like a fat guy sweats at a marathon...in death valley...mid august
Old Apr 25, 2013 | 07:25 AM
Here s the diagram for it. #11
Here is what it look like. Good to check.
http://www.ecstuning.com/Search/11437513891/ES2150908/
Hope that helps.
Old Apr 25, 2013 | 01:39 PM
thulchatt's Avatar
thulchatt
Just as a follow-up, I did the valve cover gasket but it was not the source.
Turns out it was a leaking oil catch can. Did not even think about it until I was getting ready to re-check the crank angle sensor O-ring. Saw the leak and am now good to go.
Learned that most of this MINI work in the service mode is not too bad.
woodstudio
Mar 15, 2020 08:28 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
SheldonCooperS
Aug 25, 2015 11:57 AM
ShadyCoop
Aug 24, 2015 06:05 AM
azntaiji
Aug 13, 2015 03:24 PM
