R50/53 At what point should I upgrade my clutch?
Hey guys.
I'm planning on installing a new Crower NS1 cam, Megan Racing header, 550cc injectors, and a GIAC tune in addition to a custom catback, Alta intake and a 16% pulley and I'm wondering at what point the stock clutch starts to not be able to handle the power?
The IB/W in my sig is long gone btw so my current one is running a stock clutch if you were confused by that.
In my experience the stock clutch is good up until about 250hp or so so not until you do a sprintex or big valve head you shouldn't have an issue.
So with the same train of thought you don't think about changing your oil until you have a rod bearing fail on you?
Seriously. Think about it and do a search on all the clutch failures under the assumption they needed the high performance aftermarkert clutch that fails within 10k or so miles and yet with some heavily modded cars like MINIman S stated the stock clutch holds up better then most aftermarket ones. Do a search and see for yourself.
I simply gave my opinion and you thought I was confused. Then you came back with this
I simply gave you my opinion based off of this
So I gave my opinion that you should not worry until it slips and from your question your mods should not cause any issues with the stock clutch. Thats all I was saying. So you began the arguement. But I am sorry it happened.
Hey guys.
All you had to say was "your mods should not cause any issues with the stock clutch", but you never did.
The reason I came back at you with the oil comment was because not worrying until it slips doesn't make sense to me. What if the clutch is just slipping because it already has 88K miles on it and the extra power was the tipping point in making it slip? How would I know if the miles+extra mods were the cause or if a stock clutch just can't handle it? Then how would I know what to replace with?
I put a new BVH, cam, and injectors in a few months ago and shortly thereafter my stock clutch with 60K started slipping. At first, I figured it was the additional power and/or older clutch. However, once I got into it, it turned out to be a leaking tranny seal which I replaced along with a new clutch. I ended up getting an OS Giken but after some research found out up to 250HP the stock should be fine. In fact Colin, has over 270HP and the stock is working for him. Good luck!
marendt428
Nov 14, 2015 10:03 AM
Colt45Magnus
Aug 12, 2015 06:43 AM
marendt428
Aug 8, 2015 04:44 AM
you are the man.
