R56 Where to get oil drain plug ring/washer?
Old Mar 4, 2013 | 11:34 AM
HKSpeed's Avatar
HKSpeed
I'm planning to do an oil change on my wife's 08 justa for the first time. Where can I get the oil drain plug washer/ring? I've seen them online for $5-10 each, which is ridiculous when I'm used to paying $1 each (as part of a 5-10 pack) for my Toyota and Mazda. I plan on using a MANN filter (http://www.amazon.com/Mann-Filter-HU.../dp/B001DRLPOY). Thanks.
Edit: This is the best deal I found for $2.22 shipped.
http://www.ebay.com/itm/281067048513
Old Mar 4, 2013 | 11:42 AM
RobertJ's Avatar
RobertJ
I don't know what the year of your Mini is, but for gen-2 if you buy the Mini filters they come with it along with the o-ring for the filter housing.
Old Mar 4, 2013 | 12:03 PM
Capt_bj's Avatar
Capt_bj
any auto part store!
all you need to know is the size - they have all sorts of soft seals like this
inner diam' is 16mm and width of the ring 3mm on one I just measured from an OE filter kit.
Old Mar 4, 2013 | 12:04 PM
HKSpeed's Avatar
HKSpeed
perhaps I should just get the OEM filter and not worry about this mess. just to clarify there are 3 rings associated with the oil change process?
  1. metal washer for drain plug
  2. large rubber ring for oil filter housing
  3. small rubber ring for filter/housing
Old Mar 4, 2013 | 12:14 PM
Capt_bj's Avatar
Capt_bj
no
OE kit will have 3 pieces
1 - filter
2 - o-ring for the canister that the filter fits in
3 - seal for the bung
(image from minimania.com)
Old Mar 4, 2013 | 08:40 PM
millerb7's Avatar
millerb7
Honestly just but the OEM. I get OEM filter and oil both for less than anything at autozone from my dealership.
Worth it IMO
Old Mar 4, 2013 | 09:00 PM
Porthos's Avatar
Porthos
MANN is not bad at all just FYI. I run that on my BMW and they are good to go. OEM is a great choice also and comes with everything you need. The only thing I would like to suggest is this,
http://new.minimania.com/part/G2NME1...9-60-Cooper--S
Old Mar 4, 2013 | 10:14 PM
HKSpeed's Avatar
HKSpeed
I had good experience with Mann filters on my previous VWs and Audi. Perhaps the MANN filter will come with the washer. One reviewer in Amazon wrote it did but another wrote it didn't.
Edit: Mini Mania sells the MANN filter with the washer. http://new.minimania.com/part/G2NMK1055
Old Mar 5, 2013 | 09:22 AM
ra2fanatic's Avatar
ra2fanatic
There are many things I go for in the aftermarket, the oil filter is not one of them.
Old Mar 5, 2013 | 09:42 AM
DTH2CHRM's Avatar
DTH2CHRM
I agree. I've done two oil changes on my MINI thus far and have used MINI's oil and OEM filter. I plan on changing to Amsoil for my next oil change but I'm still going to use an OEM filter.
Old Mar 5, 2013 | 10:10 AM
ra2fanatic's Avatar
ra2fanatic
Amsoil is a great brand. I've stuck with Mobil1 0W-40 Euro Formula
Old Mar 5, 2013 | 10:16 AM
HKSpeed's Avatar
HKSpeed
MANN, Hengst, and Mahle make oem filters (and other parts) for BMW, Daimler-Benz, VAG (Volkswagen Automotive Group), and other car companies. I don't have a worry going with any of their branded filters.
Although MANN, Hengst, and Mahle are German companies, they're also multinational conglomerates. Thus their parts can be made outside Germany. For example, MANN has a Mexican factory that supplies parts for VW and Audi's Mexican assembly plants.
Old Mar 5, 2013 | 02:08 PM
Capt_bj's Avatar
Capt_bj
Folks have brought MANN filters to me and I've put them in with no problems to date
and I know that MANN does make OE filters for many makes.
However if you look here
http://new.minimania.com/ss/MPG_NM
you can see what I've seen on my work bench - that the MANN filters for both GEN MINI are not exactly the same as the OE. How much difference does it make? I dunno. But many folks around trust WAY & he only sells the OE filter kit - and it is $11.00 - here's what Way says about oil filters for MINI on his GEN1 oil filter listing:
Don't bother trying to save a dollar. Get these original MINI oil filter kit to change your oil. We only use these OEM filters in the shop for customer MINI's. Many aftermarket filters don't fit correct or the O rings will leak.
IME he ships fast and via USPS flat rate boxes. Buy a handful and reduce your shipping cost per item! Or get a cabin filter and an engine air filter at the same time and save on postage that way . . .
On the other hand I can get the OE from my dealer for $12 and pay no shipping . . . he's an hour away but when I'm over that way and I'm down to one I pick up 4 . . .
Old Mar 5, 2013 | 02:48 PM
HKSpeed's Avatar
HKSpeed
I found the dealer near me has oem filters online for $9.20 ($14 if you buy in person). Their website quoted me $8.60 shipping, but pick-up is available (I'm 20 miles away). So I got 3. Anyone in the Los Angeles area should stock up.
http://www.shopminiusa.com/PRODUCT/6...CenterId=31642
Old Mar 5, 2013 | 02:59 PM
Capt_bj's Avatar
Capt_bj
A successful student of ECON ONE !!!!!
Good job!
woodstudio
Mar 15, 2020 08:28 AM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
