R56 Problem
Old Mar 2, 2013 | 09:43 AM
wariosport's Avatar
wariosport
Problem
Does anyone know what this means?
Old Mar 2, 2013 | 09:45 AM
MNIPWR's Avatar
MNIPWR
One of your lights are out.
Old Mar 2, 2013 | 09:47 AM
wariosport's Avatar
wariosport
Ok thanks. I had minor fender bender. I just picked it up from the Auto Body repair shop and this is on.
Old Mar 2, 2013 | 10:14 AM
wariosport's Avatar
wariosport
How do I figure out which bulb? I checked and can't seem to find one out.
Old Mar 2, 2013 | 11:09 AM
gregsmini's Avatar
gregsmini
They can be difficult to find. I had a reverse light that worked off and on after being rear-ended. I would get this warning light intermittently. You might have to keep checking closely until you find it. The license plate bulbs are also difficult to see.
One last thought would be did the body shop use the correct bulb? That might give you a warning also.
Old Mar 2, 2013 | 02:45 PM
Melangell's Avatar
Melangell
It means you have 59 miles left before you run out of gas.
Old Mar 3, 2013 | 05:54 AM
wariosport's Avatar
wariosport
LOL. I miss living in Savannah. The hunt for the bad bulb continues.
Old Mar 3, 2013 | 09:13 AM
jimba's Avatar
jimba
NO!, it means your parking brake is on!
Old Mar 3, 2013 | 09:43 AM
countryboyshane's Avatar
countryboyshane
It means your MINI is about to self-destruct. You cannot continue your journey.
Old Mar 3, 2013 | 01:48 PM
DogT's Avatar
DogT
Now it couldn't be too hard to figure out which bulb would be out, but like the other poster says, looks like you're emergency brake is on.
I like the other problem where the horn goes on all the time. That sounds like a 'feature' to me.
Old Mar 6, 2013 | 01:16 PM
strobeyprobey's Avatar
strobeyprobey
Refer to these instructions to narrow down which light is triggering the Check Control Message (indicated by the little triangle):
https://www.northamericanmotoring.co...-messages.html
Old Mar 6, 2013 | 01:23 PM
sean5294's Avatar
sean5294
I thought it meant the Flux Capacitor was not fluxing, lol
UncDeo
Nov 4, 2019 04:08 AM
tylewis
Sep 6, 2015 01:07 PM
mikeandtricie
Sep 4, 2015 01:42 PM
mimaal
Sep 4, 2015 09:09 AM
Sep 2, 2015 09:05 AM
