R60 USB Port Music Questions on this thing
I have successfully connected a Flash Drive to the USB port by the EBrake. It plays fine.
In the Owners Manual it indicates that when you plug in the USB it may take abit and also indicates you can have up to 4 USB Devices worth of songs or 20,000 songs available.
What this suggests to me it is downloading the USB and storing the MP3 someplace on board in it's own storage.
Is my assumption correct ??
and if it is correct how do you delete the data that has been stored.
If it is not correct about downloading it, how do you connect 4 flash drives to the USB port ??
Willie
Willie
I'm pretty sure it just stores an index of your songs so it can load more quickly in the future.
As for 4 drives--it can index 4 drives but that doesn't necessarily mean you can connect them all at once. I guess you could connect 4 with a USB hub, but I don't know why you'd want to, honestly. It would take an eternity to find what you were looking for. If you connect a 5th drive, it probably deletes either the oldest drive or the least recently used drive.
Now if ya wanna discuss GPS's I am over the top with those, owning 5 of the suckers and travel with 2 on the FJR.
Makes sense on the index versus storing the stuff, otherwise it should continue to play after you disconnected the Flash Drive.
Thanks for comeback on my questions
Willie
Maybe this will help https://www.northamericanmotoring.co...cted-faqs.html
Didn't see anything in there on the USB..hope my speed reading didnt get the best of me. But it has given me some ideas on Pandora. Not sure if I want to drink the iApple juice thou.
Willie
How can we use Pandora without an iPhone? I have Galaxy S3 android and I currently plug my phone USB into car (to charge) and then connect Audio cable from phone to car, then select Aux input.
This is my Pandora solution. Is there a better option?
Had a galaxy nexus when i got my car, but switched to the iphone 5. What i used and still do is a bluetooth adapter that also charges any phone called tunelink blue potato. Sounds great!
I haven't played around with using a USB Hub and multiple drives. I'd probably just try connecting one large drive first and see what happens. I'm not sure if there is still a drive size limitation - it may be that it can only read FAT/FAT32 drive formats, and that would give you the 32GB drive size limit. So I guess in that case you could benefit from multiple drives depending on how large your collection is.
Yes, you can. I leave my phone plugged it and it charges after I shut off the engine.
I know this is the R60 board, but i thought i'd chime in since i just noticed this AM on my R55 that the USB port stays powered on after i shut off and lock my car. The orange light on my 8GB Sandisk Cruzer drive keeps pulsing. I yanked the drive and put it in my cup holder after i saw that. I figure the drain on the battery is minimal, but my car stays parked at work for 10+ hours. I figure this can't be a good thing over the long haul. Thoughts?
The drain to support a USB thumb drive is so miniscule that you could probably go weeks without any significant problem, even with the MINI small battery.
I have connected w/ nav and I noticed that there's a whining nice coming from behind the console where the CD player is. It runs for a few seconds every time I open the doors then stops. Sounds like some is spinning, does anyone noticed this on their car?
I notice it as well on my '13 w/ Connected.
I get the spinning nose when I leave a CD in the player. Otherwise stays quiet for me.
penguinhomey
38
Jul 7, 2019 09:24 PM
siriuszero
Sep 17, 2015 04:41 AM
tippin
Aug 5, 2015 08:43 AM
