Help my mini won't start
Old Feb 23, 2013 | 02:39 PM
Scrapperjill's Avatar
Scrapperjill
Looking for advice on my 09 mcs. Drove just fine one day then wouldn't start the next day. :(. When the keys in the radio works... As well as the windows and all dings... When I hit start the engine turns over and tries... But won't start. I've had issues with my chain tensioner and just had the dealer do work on that in December. Any thoughts, ideas or suggestions would be appreciated.
Old Feb 23, 2013 | 05:05 PM
Scrapperjill
Ok... Maybe I need to add more info. I filled up my mini last Thursday... Friday drove it out to dinner... No problems at all. Saturday my bf checked my oil.. Level was good. He moved the car out of the garage to sweep the garage... Then pulled the my car back in... Sunday evening I hopped in my mini n it wouldn't start... All the lights, radio n windows work. When I push start it tries to do something... Keeps trying... Until I push stop. One time it barely started then puttered off or died.
Old Feb 23, 2013 | 05:32 PM
jcauseyfd's Avatar
jcauseyfd
Sounds like HPFP.
Old Feb 23, 2013 | 05:59 PM
Scrapperjill
What's HPFP?
Old Feb 23, 2013 | 06:11 PM
minsanity's Avatar
minsanity
High pressure fuel pump. A common r56 fail.
Old Feb 23, 2013 | 06:24 PM
DneprDave's Avatar
DneprDave
Mine did that the other day. I stopped for gas and when I was done, I pushed the start button and it just cranked without starting. I tried again, with my foot on the gas, It started and ran roughly but, with my foot still on the gas, smoothed out. It has run just fine since.
I think the Engine Control Unit had a brain fart and thought the engine was cold when it wasn't, it seemed like it was flooded when it started.
Dave
Old Feb 23, 2013 | 06:40 PM
Scrapperjill
Ah... Well i was leaning towards thinking fuel pump after reading other threads on here... I went out today to try n listen for the pump to prime when I put the key in n heard nothing. I do hear something when I first open the door... But I can't imagine that'd b the fuel pump.
Should I b able to hear the fuel pump prime at any point??
Old Feb 23, 2013 | 07:17 PM
daflake's Avatar
daflake
Actually the fuel pump does prime when you open the door. It preps the car for start.
Old Feb 23, 2013 | 07:23 PM
Scrapperjill
does it really!! I defiantly heard something when I opened the door. Never would of thought the feul pump would prime then though.
Are you serious... It primes when u open the door?
Old Feb 23, 2013 | 07:25 PM
daflake's Avatar
daflake
If I remember correctly it does. Do you have nav? That also spins up and makes noise.
Old Feb 23, 2013 | 08:30 PM
Scrapperjill
No I don't have nav
Old Feb 25, 2013 | 08:34 AM
reelman2's Avatar
reelman2
I wonder if there is an issue with a brief start and shut off in cold weather?
I just had a similar issue last week with my '08 MCS 70k miles. Still in the shop after had to have it towed 2hrs to nearest dealer. Had started the car for a few minutes to move it in the drive on Sunday. Then went to go to work Monday morning and just sputtered and then kept cranking until I stopped it. SA at the shop said the tech had a hard time getting it to start and when he did it ran very rough.
After inspection I was told the motor seemed to be flooded with gas and they recommended an oil change due to fuel in the oil and change the plugs because they were all fouled up now. No determination made at that point as to why it was flooded. Now they want to check the timing since the tech heard "the rattle" on the next mornings cold start. Will see what they have to say yet today.....
Old Feb 25, 2013 | 10:26 PM
Scrapperjill
YES!!! That was it. Had it towed today.... And got the call this evening that it was flooded. He said those engines don't like the quick start n stop... With the fuel injection they need more run time than just rolling back a few feet then again to go forward a few feet. When I called him this morning n explained what was going on he said that's what he thought it was n tried to walk me through clearing the gas line..... When I talked to him this evening he laughed n said I almost had it.
He checked my oil as well n said I'm good to go... Anywho he's going to take it for a quick drive in the morning again m make sure it's running tip top then call me for pick up
Old Feb 26, 2013 | 06:00 AM
reelman2's Avatar
reelman2
Hope you end up with better luck than mine. They wanted to check timing and turns out my chain is shot. Guide rail on one side completely missing, assumed to be laying in the oil pan somewhere. Also needs valves cleaned and turbo oil line starting to leak. $3200 to replace timing alone.
Old Feb 26, 2013 | 08:34 AM
MiniShield's Avatar
MiniShield
I hear a humm whenever I unlike the doors ( the doors are still closed). Is that the fuel pump? I was always wonering what that hum was. It goes away after about 5 seconds.
Old Feb 26, 2013 | 09:34 AM
Scrapperjill
I've had my timing chain worked on twice now... Most recently in December..... When they replaced the chain. So that was on my mind.... N the mechanic did look that over.
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
tippin
Aug 5, 2015 08:43 AM
