R56 Warning light after replacing battery
Old Feb 18, 2013 | 08:06 PM
edwin814's Avatar
edwin814
The battery on my '07 MCS died last night, so today I replaced it with Interstate battery that's compatible with this car. Now I get a warning "increased battery discharge", and the time keeps reset. After I replaced the battery, I let it idle for a good 10 min but only drove about 2 miles to the gym and back. Do I just need to drive longer distance to charge? Can I just hook up my battery tender overnight? Or should I bring it to the shop, since I read here that IBS may get messed up after battery replacement?
Old Feb 19, 2013 | 04:06 PM
cnolan
I just swapped my 07 MCS battery and didn't have any of these issues. I would put the battery on the tender until fully charged, make sure you tightened the terminals down tight.
See what happens. If the same issue continues it could be due to battery dying because of some phantom drain issue ...
Old Feb 19, 2013 | 05:48 PM
Braminator's Avatar
Braminator
Believe it or not it could be a bad new battery. Take it to Advance Auto if you have one as they have a machine that can test the charging system and let you know if there is a drain somewhere.
Old Feb 19, 2013 | 08:08 PM
edwin814's Avatar
edwin814
Thanks for the advises. I put it on battery tender tonight and see what happens tomorrow.
Old Feb 20, 2013 | 06:04 AM
RSchleder's Avatar
RSchleder
A few months ago I replaced my original battery in my 2007 S with a direct Mini replacement and did not get any codes. Everything worked fine and no problems to date of any kind.
Old Feb 20, 2013 | 08:35 PM
edwin814's Avatar
edwin814
Happy to report that after hooking the new battery up to the battery tender overnight, the error msg went away the next morning.
Old Feb 20, 2013 | 08:37 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
FYI the battery is suppose to be registered to the car computer when replaced, so this could be part of your problem, but need the BMW computer to do it.
Old Feb 20, 2013 | 09:05 PM
Braminator's Avatar
Braminator
Way how about an explanation for everyone on why this needs to be done.
Old Feb 21, 2013 | 04:16 AM
Rgoodwin's Avatar
Rgoodwin
Bought my wife's 07 Cabrio in June. Battery shot craps 3 days later on a trip. I replaced it in O'rielly's parking lot and have never had a problem. The battery in my 08 is 5 years old in August but connections look a little different. May have to take to dealer 160 miles away for programming.But not sure. Oh, Baron MINI did reimburse us for the battery which was cool!
Old Feb 21, 2013 | 05:16 AM
lowsid3r's Avatar
lowsid3r
We have the software to reprogram/reset yhe battery... Tripometer at my shop.
From what I understand. As the battery ages the car changes it's charging rate to the battery. I would guess slowing down current as the battery ages since it is losing capacity.
Correct me if I am wrong. This is done on a lot of BMWs too.
Old Feb 21, 2013 | 05:21 AM
Braminator's Avatar
Braminator
So why does it need to be registered to the car with a special computer?
Old Feb 21, 2013 | 05:27 AM
lowsid3r's Avatar
lowsid3r
I don't think it is that the battery needs to be registered. I believe it is just a kind of counter that times and monitors the battery that needs to be reset. Not sure why they wouldn't make it so you could do it your self like the rest of the service lights.
We have just received the software. So I am still learning about it. It is done through the obd2 port and a laptop. It's called Bavarian technic if you want to read up on it.
Old Feb 21, 2013 | 06:05 AM
Braminator's Avatar
Braminator
I see nothing on there that mentions resetting or reregistering a battery. So please once you figure out the software, post your info to help your fellow MINIacs understand why this needs to be done. Thx
Old Feb 21, 2013 | 06:09 AM
lowsid3r's Avatar
lowsid3r
Will do! I will search around I remember seeing another thread on it a couple weeks ago. Not sure what forum it was in. If I find it I will post a link in here. Sorry I can't spread more light on the subject yet.
Old Feb 21, 2013 | 01:45 PM
DogT's Avatar
DogT
Register a battery? Sounds like 'open your wallet' to me.
Old Feb 21, 2013 | 02:17 PM
lowsid3r's Avatar
lowsid3r
Registering the battery replacement
Why register the battery replacement?
After fitting a new battery, the service function 'Register battery replacement' should be run. Registration of the battery replacement is necessary to notify the power management (software in the engine electronics and intelligent battery sensor) that a new battery has been fitted in the vehicle.
Without registration of the battery replacement, the power management does not run properly and this can lead to function limitations, for example reduction or deactivation of individual consumer units.
This function informs the power management in the DME/DDE of a battery replacement. The following operations are performed:
  • The current kilometre reading is stored for the battery replacement.
  • The stored measured values (battery charge statuses, current, voltage, temperature, etc.) are deleted.
  • The power management is initialised.
Replacing the battery: other battery capacity or AGM battery
As the battery depends on the engine ands options fitted, the following information is coded in the CAS:
  • Battery capacity (for example 90 Ah)
  • Battery type: AGM battery or lead-acid battery.
In the case of battery replacement, in general the battery capacity used as series standard may be used.
On installation of a battery with higher or lower capacity or installation of an AGM battery, Progman must be used to recode the CAS:
  • With Progman, run the retrofit ”Battery” (select battery capacity of the fitted battery).
  • Register additional battery replacements with this service function.
From another post
Old Feb 21, 2013 | 02:35 PM
DogT's Avatar
DogT
Like I said, 'open your wallet'. Do you register your pants with your underwear when you put them on in the morning? I'm outta here.
Old Feb 21, 2013 | 02:54 PM
lowsid3r's Avatar
lowsid3r
Sure if you go to the dealer. We don't even charge that service with battery install.
Old Feb 21, 2013 | 03:25 PM
gregsmini's Avatar
gregsmini
Please confirm that the battery can be registered by the Bavarian Technic software. If it can, it might convince me to buy the Bavarian Technic software.
Old Feb 21, 2013 | 03:32 PM
Braminator's Avatar
Braminator
You don't charge for it because it is not needed? Where do you work and where is your shop?
I can not find anywhere that it states MINI's have adaptive charging and power management systems like BMW's.
Old Feb 21, 2013 | 03:36 PM
Braminator's Avatar
Braminator
Here is a thread about changing the battery. Some people have changed the battery with zero issues.
https://www.northamericanmotoring.co...ment-help.html
Old Feb 22, 2013 | 08:42 AM
strobeyprobey's Avatar
strobeyprobey
Missed a day in the thread, removed duplicate content
Old Feb 22, 2013 | 08:47 AM
Braminator's Avatar
Braminator
This was posted further above. But people are still changing their batteries without doing this and without any problems.
stevepsd
35
Dec 6, 2022 03:22 PM
bneer
Jul 15, 2019 04:41 PM
Zettinger
Aug 25, 2015 04:04 PM
JamJam43087
Aug 16, 2015 02:02 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
