Suspension camber plate question
Old Feb 17, 2013 | 02:37 AM
scoopy's Avatar
scoopy
hi what brand of camber plate that doesn't affect the front ride height of the mini? thanks
Old Feb 17, 2013 | 04:26 AM
jkapinos's Avatar
jkapinos
Vorshlag.
Old Feb 17, 2013 | 06:38 AM
scoopy's Avatar
scoopy
thanks. anything else ...what about the IE fixed camber plates
Old Feb 17, 2013 | 06:54 PM
ColinGreene's Avatar
ColinGreene
It may raise your car slightly but they are a great deal for the money.
Old Feb 18, 2013 | 06:39 AM
scoopy's Avatar
scoopy
currently im running fsd and stock springs. do i need any spring perch or 60mm or 2.5" i saw that as an option in wmw website.
Old Feb 18, 2013 | 11:16 AM
quikmni's Avatar
quikmni
The H-Sport (Hotchkis) adjustable plates do not increase ride height.
The IE fixed plates increase ride height about 1/8".
Old Feb 18, 2013 | 03:03 PM
scoopy's Avatar
scoopy
ok thanks. ive read it before that if you put adjustable camber plates they create a sound. does vorshlag and h-sport have that? thanks
Old Feb 18, 2013 | 05:02 PM
quikmni's Avatar
quikmni
I have the H-Sport adjustable camber plates which have a steel bearing at the top mount instead of the stock rubber mount so the H-Sport camber plates do add a harshness that you can feel. I guess I can hear a little noise but your really should not be able to hear a noise, I suspect my bearings are worn and need replacement. The bearings are replaceable. I have never replaced the bearings and I have about 90,000 miles on the plates. My bearings have clunked a little when the bearing needed to be lubed.
With stock size springs (not coil-overs) you do not need the optional size spring perch.
The fixed plates do not add any harseness or noise because they still use a rubber top mount.
Old Mar 1, 2013 | 06:40 AM
scoopy's Avatar
scoopy
ok thanks. i've ordered ireland fixed camber plates for now. thanks for the replies
Old Mar 1, 2013 | 06:44 AM
Helix13mini's Avatar
Helix13mini
The IE fixed plates are a great value. If you live in the Northeast, or where you get a lot of snow, I've noticed that they don't hold up to salt and snow very well, so budget for rusty parts replacement.
Old Mar 1, 2013 | 06:50 AM
scoopy's Avatar
scoopy
oh ok i'll take note of that
Hippiehobbit267
Dec 3, 2019 04:22 PM
WestfaliaR
Aug 19, 2015 08:01 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
