Newbie Wheel Question
Old Feb 16, 2013 | 01:51 PM
CPA.boom's Avatar
CPA.boom
Hi all, so I have the option of picking up a set of 17x7.5 +40 Gram Lights 57c's for my 2006 Mini Cooper S-- me and my buddy just did a test fit (rim only) and it doesn't appear they will rub, and it appeared the stock lug bolts work with the aftermarket wheels (which I was surprised by)
So I need to jump on these if I am going to. I tried doing some research but I am running out of time if I want to get them mounted and balanced today.
Will these work ok? Do I need anything else? I came across a lot of discussion on hub centric rings, but no real consensus on them. The hub bore of the wheels is ~60mm with a tape measure, which is quite close to the Mini's hub size. And my logic is that since the stock lug bolts are acorn-shaped, they should center the wheel on the hub.
Any guidance would be greatly appreciated! I don't want to run into any roadblocks if I bring them over to the local NTB to get mounted today!
Thanks!
Old Feb 18, 2013 | 04:01 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
The wheels will fit, so will the OEM bolts.
In general if you can get hubcentric rings for any aftermarket wheels that are not an exact fit over the 56.1mm MINI hub, you should do it. In a pinch you can use the wheels without the rings but make sure they are centered before you tighten everything down.
Compared to stock the 17x7.5" wheel with et40 will stick out about 8mm or 0.3" more.
Old Feb 18, 2013 | 04:11 PM
CPA.boom's Avatar
CPA.boom
Thanks, I appreciate the reply. I got the wheels mounted, and they look great. However, 3/4 ended up being slightly bent. They did balance out, but I do notice a very slight vibration over 60 mph (not shaking, but some minimal added vibration). I also feel as if they are noisier, which I am not sure is from the bends or if its just siuce they are so much lighter. I am concerned about the wheel bearings, but I don't know if there is any real side effect since they balanced out. Have any thoughts on that??
Old Feb 18, 2013 | 04:15 PM
minihune's Avatar
minihune
If the wheels are visibly bent you can ask around for a wheel repair service in your area, usually they can repair a wheel and minimize that problem. Then you can rebalance and see it that helps.
Also if you have lots of mileage on your MINI check the suspension bushings for wear especially the front lower control arms
Old Feb 20, 2013 | 04:31 PM
CPA.boom's Avatar
CPA.boom
I am already inquiring with different repair shops in the area. They look so badass, might as well make them straight!
Old Feb 20, 2013 | 08:20 PM
mini coop's Avatar
mini coop
At higher speeds the lack of centering rings becomes more noticeable.
Old Feb 21, 2013 | 04:58 AM
CPA.boom's Avatar
CPA.boom
In this case, I don't think it's from not having rings. The wheels are centered on the hub. It's likely the visible bends
Old Feb 21, 2013 | 06:43 PM
mini coop's Avatar
mini coop
Visually perhaps...........others who had posted have said they look centered but when they got the rings it made the difference. They are cheap. Why wouldn't you get them?
Old Feb 23, 2013 | 04:40 PM
CPA.boom's Avatar
CPA.boom
Interesting. Well, there really isnt a lot of room between the hub (~56mm) and wheel bore (~60mm). Plus, the lug bolts assist in centering the rim.
I am going to get the rims straightened, so I will definitely assess the vibration level again once they are fixed and go from there.
Old Feb 23, 2013 | 04:54 PM
minihune's Avatar
minihune
Centering rings for 60mm-56.16mm are available
sample picture of thin rings
G1HQ
Dec 7, 2015 02:23 PM
thebordella
Aug 31, 2015 01:37 PM
Mini'mon
Aug 16, 2015 04:15 PM
ki7hy
Aug 12, 2015 07:07 PM
nomar116
Aug 10, 2015 11:24 PM
