R50/53 Anyone done Corvette Blades on an MCS.
Old Feb 16, 2013 | 01:46 PM
ishoelaceee's Avatar
ishoelaceee
Just wondering if anyone on the forum has done Corvette Blades on an mini cooper. I am trying to find the adapter to go from 4 lug to the 5 lug pattern of the blades. If anyone has any insight that would be awesome.
Old Feb 16, 2013 | 02:24 PM
Longboard110's Avatar
Longboard110
What do corvette blades look like?
Old Feb 16, 2013 | 02:43 PM
maxmini's Avatar
maxmini
Its been done several times . You should be able to find some info here .
http://www.motoringunderground.com/f...ad.php?t=15429
http://www.motoringunderground.com/f...splay.php?f=26
Old Feb 16, 2013 | 02:51 PM
calforhelp's Avatar
calforhelp
This guy changed his wheel hubs or something to be a 5 bolt pattern.
EDIT:
I found a pic of these but I have no idea of their model number.
Old Feb 16, 2013 | 03:16 PM
MSFITOY's Avatar
MSFITOY
Enkei made a similar wheel like the blade...had it on my old CRX...I think the bolt pattern were the same 100/4...looked like this...
Old Feb 17, 2013 | 07:27 PM
chaseabryant's Avatar
chaseabryant
Is the "blade" what people refer to as "salad shooters"?
-Chase
Old Feb 17, 2013 | 07:33 PM
ishoelaceee
The salad shooter is the white rim on the grey mini in the above pictures. The Blade actually came on a newer corvette like a 94.
Old Feb 19, 2013 | 01:29 PM
martinb's Avatar
martinb
I'd avoid using adapters and find a wheel you like that'll bolt up properly.
Old Feb 19, 2013 | 02:00 PM
Miniman s's Avatar
Miniman s
If you just want a 5 lug wheel I have been trying to sell my adapters that change the pattern to 5x100
Old Feb 19, 2013 | 02:36 PM
rickyr53's Avatar
rickyr53
Not a guy, thats Ashleys car. Adapters were used, and they are not Sawblades.
Old Feb 19, 2013 | 02:37 PM
rickyr53's Avatar
rickyr53
Why is that?
Old Feb 20, 2013 | 09:46 AM
cerksies's Avatar
cerksies
Originally Posted by rickyr53
Why is that?
Lug adapters & spacers that are thick enough to require being bolted down introduce additional points of failure. Last thing you want is your wheel falling off when going around a corner.
They also add un-sprung weight
They also add spacing so depending on the wheel you choose your offset might be completely wrong and your wheel will stick out too far.
Old Feb 21, 2013 | 12:42 PM
Miniman s's Avatar
Miniman s
Let's be honest a quality adapter installed correctly will have about as much a chance of failing as the hub itself. It does change spacing and it does add weight but for most people wheels aren't about weight they are about looks and there are just more options out there in the 5 lug pattern.
Old Feb 21, 2013 | 09:04 PM
ColinGreene's Avatar
ColinGreene
^yep
Doc Pain
Mar 10, 2021 04:50 AM
freeman727
Dec 10, 2017 04:00 AM
minimofo
Jan 26, 2016 11:32 PM
cub4bearindiana
Oct 2, 2015 09:45 AM
Sep 3, 2015 12:24 PM
