JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW blow off valve
Old Feb 11, 2013 | 01:26 PM
JCWKART's Avatar
JCWKART
blow off valve
Has anyone replaced the factory bov for a different/better sounding one?
Old Feb 11, 2013 | 03:10 PM
MinMin2010's Avatar
MinMin2010
If you are wanting a BOV that actually has a performance advantage, look into the Forge BOV/diverter. If you are just wanting the sound, keep the factory one.
Old Feb 11, 2013 | 03:45 PM
JCWKART's Avatar
JCWKART
I didn't know that a bov could add performance,did you know of a brand or site?
Old Feb 11, 2013 | 03:55 PM
MinMin2010's Avatar
MinMin2010
http://www.waymotorworks.com/forge-blow-off-valve.html
Old Feb 11, 2013 | 07:25 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Like posted above the Forge Valve is the one to go with.
Old Feb 11, 2013 | 07:35 PM
JCWKART's Avatar
JCWKART
thanx for the info but i still don't see where the increase in performance comes in?
Old Feb 12, 2013 | 03:14 AM
MinMin2010's Avatar
MinMin2010
Did you not read the description of the product?
"This product has been thoroughly designed and tested with the expressed intent of offering improved valve response and maintaining ECU control while resulting in absolutely NO fault codes, NO check engine lights, and no adverse effects of any kind. All of the necessary components and detailed instructions are included and everything is designed to make installation as simple as possible. Simply put this valve will improve throttle responce and boost control to enhance the drivability and performance of your MINI."
Old Feb 12, 2013 | 04:13 AM
JCWKART's Avatar
JCWKART
For some reason it just made sense to me by reading it again,thanx
PsychoRallye
21
Feb 17, 2019 06:08 AM
olson187
Oct 21, 2015 05:25 AM
Fordgt4
Oct 10, 2015 10:42 AM
Southern Marylander
Oct 1, 2015 07:53 AM
Nicefeet
Sep 24, 2015 06:53 PM
