R56 warning indicator help
Old Feb 7, 2013 | 06:52 PM
bruiseman's Avatar
bruiseman
I just bought my first mini and I bought it used. There is a triangle with an exclamation point in the middle of it between odometer and trip odometer. Any thoughts on what it is indicates. I can not find it in the owners manual anywhere.
Old Feb 7, 2013 | 06:53 PM
Mathen001's Avatar
Mathen001
Traction control? Just a guess.
Old Feb 7, 2013 | 07:15 PM
Braminator's Avatar
Braminator
Here maybe this will help.
https://www.northamericanmotoring.co...top-manual.pdf
Old Feb 7, 2013 | 08:42 PM
RJKimbell's Avatar
RJKimbell
In a nutshell it means your OBC has stored a Code, in order to properly diagnose what that Code is you will need to do one of two things:
1) Find someone who has or purchase an OBD II Code Scanner.
2) Go to your local Dealer and have them read the code and advise you what your options are.
HTH
Julie
Old Feb 7, 2013 | 08:55 PM
mini coop's Avatar
mini coop
By repeatedly pushing the button at the end of the left staulk, it will cycle through computer choices. By holding the button in at the proper choice you can then go through possible sources for the triangle. It may be for scheduled maintenance, oil, tire pressure etc. It doesn't have to be as complicated as a code. It may be something simple, even blown bulb etc.
If it is something more complicated a local shop can read the code. The code can be googled for the definition.
Old Feb 8, 2013 | 01:09 PM
bruiseman's Avatar
bruiseman
Thanks for the help
It was the warning light telling me there was an issue. It is a blown blinker bulb.
Thanks everyone
Alpha Motoring
Nov 10, 2015 07:08 AM
Alpha Motoring
Oct 1, 2015 10:30 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
rt808
Sep 25, 2015 01:59 PM
