R56 Knocking sound from front end?
Hi,
I have a 2007 mini Justa with 24k miles. When the engine is cold I hear a knocking sound. This only happens when I turn to the right, which I do everytime I pull out of my driveway. I only occiurs when the engine is cold and only when I make a sharp right turn. Once the engine is good and warm it doesn't happen. Any suggestions?
If you're truly trying to remove the engine from the equation, I would think you'd want the engine completely off. Bear in mind you'll lose your power steering and brakes in the process, so find a safe place to try it. Any unusual noise you hear will be from the CV joint or front suspension. Good luck.
Interior/Exterior Need Help With Exterior Decisions (05' MCS PHM/W)
boostedhaze
Jan 2, 2018 07:26 PM
silence2-38554
Nov 12, 2015 09:39 AM
gmonde
Sep 8, 2015 06:37 AM
