Suspension M7 Rear Chassis Brace
Old Jan 25, 2013 | 07:14 AM
JCWKART's Avatar
JCWKART
Has anyone installed this brace on there R56 yet on this forum? If so could you post pic's so i could see what it look's like, also how did it work for you? Thanx
Old Jan 25, 2013 | 10:58 AM
countryboyshane's Avatar
countryboyshane
Boy oh boy Peter is a master salesman. $321 for a bunch of scrap metal and bolts. These braces are such a waste of money. The only worthwhile chassis stiffener is a 4-point roll bar or a full cage.
You must really want to spend that money! What have you done to your JCW already? There are much better things to throw money at than this piece of crap.
Old Jan 25, 2013 | 02:03 PM
JCWKART's Avatar
JCWKART
Slow down,I'm just asking. I've done so far a hotchkis sway bar,rear camber links,eibach springs,and a m7 strut brace.
Old Jan 27, 2013 | 06:14 PM
mbwicz's Avatar
mbwicz
What are you looking for with your car, how do you use it? What are you unhappy with, or hoping to improve? What wheels/tires/brakes, other mods do you have? JCW Red suspension, or base or sport?
Mike
Old Jan 27, 2013 | 08:03 PM
jtack's Avatar
jtack
I think the TSW x-brace (under car) is a better way to stiffen the chasis.
Old Jan 27, 2013 | 08:17 PM
JCWKART's Avatar
JCWKART
Mike
I have a 09 JCW to start with then i put eibach spring's, hotchkis rear sway bar and camber links, and a M7 strut bar. As far as tires I have Goodyear F1's, I just heard so much about the handling of mini's so i just expected more when I put it into a turn. My sway bar is set to the 2nd setting so i'm wondering if i change that would it make a big differance?
Old Jan 27, 2013 | 09:53 PM
Melangell's Avatar
Melangell
I'm having the TSW X-brace, along with TSW springs, H-sport camber links, turbo exhaust manifold and Helix Short shift kit installed by Way on the 1st. If I remember, I'll post how the changes feel.
Old Jan 28, 2013 | 06:54 AM
spiney's Avatar
spiney
I had the F1's on a Mitsubishi and wasn't that impressed. Might be worth getting a tyre recommendation here before going with the brace? I have factory Continental run flats (which I'm happy with) but there are lots of people with strong opinions here...
Old Jan 28, 2013 | 09:36 AM
JCWKART's Avatar
JCWKART
Ok, thanx for the input
Old Jan 28, 2013 | 02:22 PM
mbwicz's Avatar
mbwicz
Which hotchkis sway bar do you have? Its a pretty simple change to see if you like the RSB stiffer or softer. Do a search for the free camber mod, that makes a nice difference on the front end.
Mike
Old Jan 28, 2013 | 02:46 PM
Braminator's Avatar
Braminator
Try the 3rd setting. I run my R53 with it on the 3rd setting and love it.
Old Jan 28, 2013 | 07:43 PM
JCWKART's Avatar
JCWKART
Is the third setting the one closes to the bar or the tip end?
Old Jan 28, 2013 | 07:44 PM
JCWKART's Avatar
JCWKART
Mike
Thanx for the info
Braminator's Avatar
Braminator
Closest to the bar.
Old Jan 28, 2013 | 07:45 PM
JCWKART's Avatar
JCWKART
I'll try that,thanx
Old Jan 28, 2013 | 07:48 PM
Braminator's Avatar
Braminator
you will notice a big difference IMO. It was night and day as I changed it each time.
Teh
Aug 22, 2022 04:37 AM
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
jziran
Aug 24, 2015 04:50 PM
