p2626 error code
Old Jan 11, 2013 | 02:27 PM
Sabini's Avatar
Sabini
p2626 error code
I have 2 codes, both are 2626, but one is says pending.
as per bentley; O2 sensor pumping current circuit open(bank1 sensor 1)
My question is, since the vehicle has 2 O2 sensors, and I have 2 identical codes, does this mean both sensors are creating a fault or 1 sensor is sending 2 error codes( if that even makes any sense)
Old Jan 11, 2013 | 02:41 PM
Braminator's Avatar
Braminator
That would be the one before the cat.
Old Jan 11, 2013 | 03:09 PM
alexs3d2's Avatar
alexs3d2
Since I had the exact same issue, try to simply unplug and re-plug the O2 sensor. My problem was probably the connection. A year has passed since then and I din't get the error again. I read in another forum that the culprit is a resistor built-in to the sensor, which is used for calibration purposes.
If your problem persists, then you are looking at a new O2 sensor, which can be pricey but easy to install.
Old Oct 30, 2013 | 11:10 AM
Sabini's Avatar
Sabini
fixed, upstream 02 sensor
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
hamptup
R55 :: Clubman Talk (2008+)
18
Nov 29, 2016 05:04 PM
MiniSkoon
Sep 9, 2015 12:40 PM
MasterShaftner
Sep 4, 2015 03:52 PM
