R56 Interesting article about exhaust
Old Dec 24, 2012 | 12:30 AM
MNIPWR's Avatar
MNIPWR
I stole this from Import Tuner. I wanted to share with everyone. My conclusion is at the bottom.
The Problem
More exhaust backpressure generally means less horsepower, and a stock catalytic converter is often the greatest source of backpressure in an exhaust system. So it's no wonder the catalytic is often tossed in favor of an eBay "test pipe" when a performance-minded owner starts itching for a little more power. But there are a few downsides to de-catting a car - the big one being that it's illegal.
Hell bent on wrangling every last horsepower out of their steeds, power mongers often run sans-converter on the street; risking tickets, huge fines or even impoundment of their vehicles. But just how much power are they gaining, and is it really worth the risk? If the thought of surrendering your car to the local towing yard keeps you from yanking your converter, there still may be a way to make more power and not break the law.
Aftermarket catalytic converter manufacturers claim their products can reduce backpressure, helping to free up exhaust flow and make more power. They may have fancy CFM flow graphs and other fancy data to back those claims, but can these kitties really flow better than the OEM pieces? And, how do they compare to the good ol' test pipe, in terms of horsepower?
To answer these questions, we took a lightly-modded 1999 Honda Civic SI and did four back-to-back dyno pulls: one with the stock cat, one with a test-pipe, and two pulls with OBD II approved aftermarket high-flow cats. Read on, and see with your own eyes how powerful you can become by killing your cat.
The Test
Breathing through an aftermarket intake, header and cat-back exhaust system, our Civic mule put down a respectable 147hp and 105 lb-ft to the front wheels on K&N Engineering's dyno. Not too shabby, considering the car was still huffing through the stock OEM catalytic converter. Eager to see what we could gain by uncorking the exhaust, we bolted on the first aftermarket cats.
Aftermarket high-flow cats come with two different types of guts, metallic and ceramic. The ceramic type is less expensive to manufacture and will melt and fail at lower temperatures - not ideal for high performance applications. The metallic honeycombs can withstand the higher temperatures and richer air-fuel mixtures but are more expensive to make and subsequently cost more. But cost isn't the only factor to consider if you find yourself replacing the cat.
It's important to ensure that you have the correct type of converter for your application. If your car is OBD I compliant, you can use any EPA or CARB approved OBD I converter. If your car is OBD II compliant, your cat must be OBD II approved. As a general rule, any car 1996 or newer is OBD II and any car 1995 or older is OBD I. However, some cars were OBD II compliant as early as 1994, so double-check the underhood emissions sticker. The difference between OBD I and OBD II cats is bigger than you might think.
OBD II cats are required to remove about 90 percent of emissions, while the OBD I cats are only required to remove 70 percent. So, put an OBD I cat on an OBD II car and you might fail your emissions testing.
After removing the OEM cat, we welded and bolted up an OBD II Magnaflow ceramic-core catalytic converter in place of the stock one. With the Magnaflow cat installed, the Honda turned the rollers to the tune of 150hp and 107 lb-ft to the wheels. The ceramic-core cat netted us an additional 3hp and 2 lb-ft to the front wheels. Obviously, this cat really can flow more than stock.
Next up was the metallic core Magnaflow OBD II cat. Because metallic cats can take more abuse and richer AFRs (and generally flow more), these are often the choice of the performance-minded tuner. After much cursing and a bit of charred flesh, we put the fancy metallic-core cat onto the Civic. Apparently, the metallic core unit does indeed flow slightly better than the ceramic unit. But when we say slight, we mean slight. The metallic core cat netted us a 1hp gain (to 151hp) and no increase in torque over the ceramic core. So, unless you are running a rich AFR (like in a boosted application) the extra cost of the metallic core might not be worth it. However, if you are running a rich mixture, the metallic cat is still your best bet.
With the testing of all three cats out of the way, it was time to unplug the exhaust and let her rip without that pesky brick in the exhaust. No matter how you cut it, a cat is a restriction and costs power, right? With the moment of truth at hand, we bolted in our test pipe - eliminating the cat entirely. On our final pull we stood eagerly by the dyno's monitor, waiting to see the results. Wait ... here it comes ... 152hp and 108 lb-ft - a gain of one measly horsepower and one lb-ft of torque at the cost of breaking the law.
The Lowdown
Now that we've armed you with the facts, you should be ready to make the correct decision should you need to replace your cat. Whether or not you choose to run a cat is between you and Johnny Law. But when you consider the potential gains versus the costs, it hardly seems worth risking getting caught. With a difference of only 1hp between a straight pipe and a 49-state LEGAL cat, it seems foolish to flaunt the law and pollute the air that we all breathe. Hell, if you are only looking for those kinds of gains, just loose 10 pounds -that alone will make your car faster than adding 1 measly HP.
The 5hp gained from losing the factory cat for the metallic one is substantial. If the engine were to later receive more extensive mods, the benefits would probably be even greater. What it all boils down to is that a good aftermarket high-flow cat can indeed flow better than a stock unit, and almost as well as a straight pipe. When you can have all the benefits of removing the cat without the risk of getting busted, it's kind of like having your cake and eating it too.
A Caveat
Before you go off all *****-nilly and replace your cat, there are a few things you should understand first. Contrary to popular belief, not all cats are created equally. The stock factory cats usually do the best job of cleaning up the exhaust, but often at the cost of high backpressure. Aftermarket cat flow and ability to pass emissions testing can be iffy because quality varies greatly. In an effort to save money, some manufacturers cut corners and don't include enough of the agents that actually catalyze and create the heat to burn up the pollutants. Install one of these cats and you might not pass smog. This is why it's important to pick one that is CARB or EPA compliant. These cats have been independently tested and should pass an emissions test.
Now that you are done I hope there is more than one of you saying this is not a complete article and is misinforming. In order to receive the true benefits of a less restrictive exhaust system you need a tune that will take advantage of it. I'm slightly let down with the magazine leaving out this information.
Old Dec 24, 2012 | 11:57 AM
Porthos's Avatar
Porthos
I read this article a few years back and it really isn't saying tune your car as much as it is saying beware of taking your Catalytic Converter off because it is illegal and you run the risk of getting your car impounded.
Old Dec 24, 2012 | 01:16 PM
MNIPWR's Avatar
MNIPWR
I got that is what it was saying but they are using the fact that it wont add power as a deterrent, which we know is incorrect.
Old Dec 25, 2012 | 07:37 AM
Mannylove's Avatar
Mannylove
So, with that said.......Alta exhaust is the way to go?
I want one, but, I'm caught in the "is it worth it" mode...especially when my exhaust is in very good shape.
"Hell, if you are only looking for those kinds of gains, just loose 10 pounds -that alone will make your car faster than adding 1 measly HP".
I love this line.
Old Dec 25, 2012 | 07:47 AM
ACallahan's Avatar
ACallahan
[QUOTE=Mannylove;3647412]So, with that said.......Alta exhaust is the way to go?
Or a real exhaust like Borla
Old Dec 25, 2012 | 08:07 AM
IzzyG's Avatar
IzzyG
I love this line.
Are you saying that cause Alta's is 3" and thus less backpressure? Frankly I believe a pipe is a pipe is a pipe. As long as it's also stainless steel and welded well, there's no difference between Alta's 3" exhaust and your exhaust shop's custom 3" exhaust(other than the custom being a lot cheaper). Even with Borla mufflers attached to the custom pipes, it'll still be hundreds cheaper.
Old Dec 25, 2012 | 01:32 PM
MNIPWR's Avatar
MNIPWR
If you don't have a tune or larger turbo there really is no reason or a 3" exhaust. Unless you just want the sound. If that is the only reason you will be adding a decent amount of weight.
Old Dec 26, 2012 | 08:32 AM
Mannylove's Avatar
Mannylove
I only made that statement cuz it seems to b the most popular/ preferred. I think performance wise I'm good with the stock, it's more of a sound thing for me.
ebowling
90
Aug 4, 2019 09:15 AM
TrueEddie
General Discussion
Aug 24, 2015 09:31 AM
Aug 12, 2015 01:24 PM
massmini03
Aug 12, 2015 11:19 AM
messyjesse96
Aug 12, 2015 05:51 AM
