R60 Amperage on Cig Lighter
Old Dec 21, 2012 | 08:17 AM
zoedog9's Avatar
zoedog9
Anyone know what the max amperage is on the cig lighter for the Countryman? Trying to get a good tire pump for the car and the one I'm looking at requires a 15-ampere minimum power port rating. I believe the Countryman has a 20 ampere fuse on the cig lighter, so I'm thinking it will be fine. But does anyone know for sure?
Old Dec 21, 2012 | 08:27 AM
ignitionmodule's Avatar
ignitionmodule
Question is a little vague about knowing whether the circuit is designed to hold 15A or the fuse is 20A.
Just pull the fuse door and look at the amperage rating for the fuse. The entire circuit will be rated for more current that what it will take to blow the fuse. 20A fuse means it will hold your 15A pump with no problems.
Old Dec 22, 2012 | 06:19 AM
y8s's Avatar
y8s
I have used a VIAIR 85p like this in my CM and it worked fine. It says it requires 14.5A maximum.
Old Dec 22, 2012 | 08:46 AM
zoedog9's Avatar
zoedog9
Great...yes that is the air compressor that I am looking at. Good to know it works well. Thanks.
Old Dec 23, 2012 | 05:42 AM
y8s's Avatar
y8s
If you're still worried, you can get alligator clip to cigarette lighter socket extension cords. I use those on my other cars with easily accessible batteries.
You may also want a straight extension cord (of heavy gauge) so you can reach all four tires. On the CM it's no problem because you've got front and rear sockets though.
fridayxiii
Mar 24, 2022 04:41 PM
pglgp1292
Aug 9, 2017 12:45 PM
Jerome R Jr W
Sep 29, 2015 11:42 AM
zsqure
R60/R61 Stock Problems/Issues
Sep 21, 2015 05:24 AM
shahriar35
Sep 14, 2015 11:53 PM
