Electrical Where to tap power source inside cockpit?
Old Dec 20, 2012 | 08:47 PM
NintenTom's Avatar
NintenTom
I'm checking out a rearview mirror with a LCD built in for a backup camera for a mod but was wondering if anyone knows where I can tap into for a power source to power the LCD.
The item in question is
http://www.ebay.com/itm/221138196872...84.m1423.l2649.
I already know for the backup camera I'll be tapping into the reverse light wires in the back, but was wondering where to tap into for power in the front? If the cigarette lighter is fine, is there a DIY on disasembling the console to access the cigarette lighter etc? Thanks!
Old Dec 21, 2012 | 05:03 AM
ignitionmodule's Avatar
ignitionmodule
For my Garmin mount in my last Mini, I tapped into the cigarrete lighter circuit under the console. Was fairly easy to do and the instructions were with the mount kit from Craven Speed. Let me see if they're online.....
Yes! PDF files towards the bottom of this page should have what you need:
http://www.cravenspeed.com/products/...nting-Kit.html
Old Dec 21, 2012 | 07:08 AM
Price's Avatar
Price
Sunroof motor plug
Old Dec 21, 2012 | 10:10 AM
NintenTom's Avatar
NintenTom
My car doesn't have a sunroof.
Old Dec 21, 2012 | 10:13 AM
NintenTom's Avatar
NintenTom
[URL]
Unfortunately it doesn't have instructiosn for the wiring harness that it mentions in the item description.
Old Dec 21, 2012 | 10:58 AM
ammodave's Avatar
ammodave
You should be able to tap into the cigarette lighter without removing the console. If you gently pull on the lighter housing with your fingernails or a small screwdriver the lighter will just pop out of the hole giving you access to the lighter harness below. You should also be able to feed a new wire under the console from the side without removing the console. Good luck.
Old Dec 21, 2012 | 11:13 AM
ignitionmodule
http://www.cravenspeed.com/product_i...wiring-kit.pdf
you're welcome.
Old Dec 21, 2012 | 11:23 AM
NintenTom's Avatar
NintenTom
you're welcome.
Big THANKS!
Old Dec 21, 2012 | 11:59 AM
gerry2153's Avatar
gerry2153
if you want a source in the overhead console, search radar install - there is a purple wire up there that works- used it as a hot lead for my gps
Old Dec 21, 2012 | 12:07 PM
NintenTom's Avatar
NintenTom
Sweet. I'm assuming there's a ground somewhere up there too?
Old Dec 21, 2012 | 12:21 PM
gerry2153's Avatar
gerry2153
yup there is a hole on the body that I used... little screw and wire ... done
Old Dec 28, 2012 | 07:23 AM
blakeslee_a's Avatar
blakeslee_a
If you do decide to gorge cigarette light route, to remove the center console all you have to do is remove the three screws in the cupholders, and give the shift **** a nice hard yank upwards and it comes right off the shifter, then just pop the ebrake boot off and the center console comes right out, took me about 5 minutes once I figured it all out
That is, if you have a manual. Not sure for automatic
Old Jan 1, 2013 | 11:48 AM
NintenTom's Avatar
NintenTom
I'm deciding now between using passenger side fusebox with a add-a-circuit or just using the headliner like gerry has done with his GPS. Only problem is finding a store open on New Years Day that sells those crimp wire splicing connectors (not sure what they're called) to easily tap power from a cable.
theblackfalcon
Oct 11, 2015 09:49 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
Super Coop
Aug 17, 2015 05:09 PM
Powershift
Aug 16, 2015 05:14 PM
