Brake pad replacement; pad sensor question
Old Apr 5, 2004 | 08:26 AM
jblow's Avatar
jblow
When replacing the front brake pads; does the brake sensor simply slide into the slot of the new pads? I have a set of Mintex reds for my '04 MCS -- there is no wiring harness for these pads -- I assume one isn't required for the front sensors on my car? Please advise.
Thanks,
Old Apr 5, 2004 | 08:30 AM
Technomage's Avatar
Technomage
As long as the sensor has not gone off, you can pop it out of the old pad with a flat headed screwdriver. Make sure to remove the little metal clip as well, and insert both of them into the new pad.
I just did this on Saturday with EBC Green stuffs.
Old Apr 5, 2004 | 12:40 PM
DesignIt's Avatar
DesignIt
Jblow,
I tried this with a set of Mintex pads on my '04 MCS on Saturday, and the sensors DO NOT FIT the Mintex pads. In order to make them fit, the metal on the brake pad around the slot that the sensor is supposed to fit into would have to be milled down to half of its thickness. I bought these from BMP, so I'm going to give them a call to find out what the problem is. I asked BMP if the sensors would fit before I ordered the pads so it makes me think that something must be different on the '04 sensors.
Has anyone else had this problem, and if so, what pads will allow the sensors to be fitted?
Thanks,
DesignIt
Toolman
Jan 20, 2016 06:50 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Yazon
Tires, Wheels, & Brakes
11
Aug 27, 2015 04:41 PM
fjork_duf
Aug 16, 2015 04:38 PM
