R56 iPod worked, then did not work - any ideas?
Hey,
I have been driving around for two months with my iPod hooked into the mini iPod cabled that plugs in under the dash. It's the Y cable that you purchase from mini.
Synced my iPod last night and this morning it charges through the cable but the car does not recognize it. When you select USB it says "Empty."
Any ideas?
Any ideas?
Try doing a reset on the ipod and then re-syncing it. Only a guess, this has never happend with mine. I listen to audio books a lot and most times the book will continue where I left off the last time and occasionally it will start over so I suspect the relationship between ipods and the MINI is less than perfect.
Sounds like what happened on my 2011, the Y cable worked for a few times then never worked again. Dealer replaced the cable still nothing. I complained about it every time the car was in the shop and they couldn't determine the issue....
Looks like there are four pins and the second one is broken - a trip the dealer will be underway.
minipopkart
Aug 13, 2015 05:22 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
