R56 Dis not know I was superman... I need help !!!
I was installing my new akra downpipe the other day and i broke one of the exhaust manifold studs due to overtightening with my superman like strength..
. Any ideas on how to get the remaining piece out so i can put in a new stud ? Any ideas will be highly appreciated ?
You can always use an easy out if you can get to the broken face of the stud to drill a hole in it to insert the easy out. In you photo it appears you can get to the other end of the broken stud and grind a slot using a Dremel tool and turn the stud out from the top side using a screwdriver. broken bolts usually come out fairly easily when they're broken from over torquing. Good luck.
If you have a little bit of the stud still sticking out, you could heat it up and drip some candle wax on the hot threads to make the wax get drawn into the threads. You'd need some channel locks to try and rotate the stud out after it is very hot.
I think the easy out could be a lost cause. Those studs are in there tight and are very stubborn from all that heat around the turbo.
You might just have to drill it out and find a grade 10.9 bolt to fit there with a respective nut.
Start by soaking the broken stud with Kroil for several hours and then the slotting technique mentioned above. I've had studs/bolts come out when I started drilling a hole for an easy out. We've been using Kroil in the airline business for decades. It works!
My advice was based on the fact that the OP said he was "installing" the bolt when it broke. In my experience when I break a bolt on installation is that it's usually not that hard to remove. Old bolts that are seized due to heat or rust are usually more difficult.
You don't need a 10.9 grade bolt..... That's OVERKILL. Most bolts on cars, with the exception of a few in suspension components, are 8.8 or less. You shouldn't have to torque it down that hard that you would snap what's there.
Just go get a regular 8.8 bolt (comparable to a standard grade 5). Figure out what the standard torque rating is, and torque it down to that.
Thanks guys... I was able to get it out using a vice grip... Now everything is installed and ready for a test drive tomorrow morning...
Sent from my iPad using NAMotoring
Had to remove the DP again and started turning the stud counter clockwise. It came out pretty fast.
Kimolaoha
Jul 5, 2023 01:04 PM
