A dreaded squeak!!!
Old Oct 21, 2012 | 04:58 PM
CassRacing's Avatar
CassRacing
A dreaded squeak!!!
I have posted a few times on this forum before, and every time you all have given me outstanding advice! So I figured I'd run this one by you all....
So there is an amazingly annoying squeak coming from (what sounds like) the rear left hand side of the car (right behind the drivers head). Its loud enough that it sounds as if it is coming from inside the car, although I cannot confirm this.
I have had the seats down, up, and greased the brackets with proper automotive grease.... all with no effect on the noise what so ever.
I know you guys can't tell me exactly what it is from my description, but maybe some ideas on what I can do to work it out? It literally sounds like a chirping bird chirping every time I go over any sort of bump.
I am begging you all for help!
Old Oct 22, 2012 | 04:25 AM
dustint's Avatar
dustint
Mine does this sometimes if the doors are unlocked. The little lock indicator on the door squeaks if it's unlocked. So, I just locked it.. I'm sure you could fix it with some felt or lube.
Old Oct 22, 2012 | 08:10 AM
submitaweasel's Avatar
submitaweasel
My seatbelt mechanism squeaks if I move at all while driving. And its right by my ear. Maybe thats what youre hearing. I just turn the music up when it decides its time to squeak.
Old Oct 22, 2012 | 10:04 AM
countryboyshane's Avatar
countryboyshane
Just get used to it. Your MINI is going to rattle and squeak more with every additional mile you put on it
Old Oct 22, 2012 | 09:18 PM
slinger688's Avatar
slinger688
I use a can of dry Teflon spray. Have some one drive while you spray it in the offending area.
Old Oct 27, 2012 | 08:44 PM
CassRacing's Avatar
CassRacing
Well, as usual you guys got it in one! The seatbelt was squeaky. Literally 1 second of WD40 cured the problem.... I was almost disappointed.... hahaha. Thanks as always!
Old Oct 28, 2012 | 09:15 AM
submitaweasel
Awesome, now I know how I can make mine shut up
USNAE2
16
Jun 17, 2022 07:17 AM
torpeau
Oct 8, 2015 11:10 AM
weaver9000
Sep 14, 2015 05:48 PM
Suspension Products
Sep 10, 2015 11:46 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
Sep 9, 2015 01:17 PM
