Interior/Exterior driver window won't roll down?
Is it staying up and then catching on the top trim and prying out?
Mine did this a couple of times during the winter, primarily because it got some ice build up on the bottom gasket and the motor couldn't drop the window when I opened the door. I put the window down about an inch and then closed the door. But its only done it when it was cold and icy.
This is a common problem and MINI repaired mine under warranty. Here is a fix that will get the window working again until you can get to the dealer.
1) Don't laugh, this really works.
2) Open drivers door.
3) Locate a spot just above the bottom speaker and just in front of door pocket
4) Form your left hand into a fist with the knuckles facing up.
5) With a strong sideways motion, solidly THUMP the door panel with the soft side of your fist on the previously located spot.
6) Roll down window.
7)
This was shown to me by the lead tech at my MINI dealer and I uesd it several times untill I goy my window fixed.
7)
same thing happen to me and i had to use the "fist" fix it until i finally got the window motor replaced on the driver side. no biggie it was covered under warranty and all is good now.
It's not a common problem...
7)
7)
Dec 23, 2015 10:36 AM
Interior/Exterior Another hood stripe removal thread
broncobuddha
Sep 1, 2015 06:32 PM
