North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   Interior/Exterior (https://www.northamericanmotoring.com/forums/interior-exterior-33/)
-   -   Interior/Exterior driver window won't roll down? (https://www.northamericanmotoring.com/forums/interior-exterior/23840-driver-window-wont-roll-down.html)
timj1231 Mar 27, 2004 08:04 PM
It started to happen randomly and now it is stuck and won't do the auto dip when the door shuts so I have crazy air noise .
Anyone else have this issue? :sad:
laclede Mar 29, 2004 06:10 AM
Is it staying up and then catching on the top trim and prying out?
Mine did this a couple of times during the winter, primarily because it got some ice build up on the bottom gasket and the motor couldn't drop the window when I opened the door. I put the window down about an inch and then closed the door. But its only done it when it was cold and icy.
minimotorin Mar 29, 2004 06:21 AM
I had to have the motor and scissor arms replaced in my window, it had stopped working completely.
jeffracer Mar 30, 2004 08:19 AM
This is a common problem and MINI repaired mine under warranty. Here is a fix that will get the window working again until you can get to the dealer.
1) Don't laugh, this really works.
2) Open drivers door.
3) Locate a spot just above the bottom speaker and just in front of door pocket
4) Form your left hand into a fist with the knuckles facing up.
5) With a strong sideways motion, solidly THUMP the door panel with the soft side of your fist on the previously located spot.
6) Roll down window.
7) :razz:
This was shown to me by the lead tech at my MINI dealer and I uesd it several times untill I goy my window fixed.
jeffracer Apr 1, 2004 06:11 AM
Just curious, didf you try my window fix?
croak Nov 14, 2005 06:08 PM
didnt work for me.
DrkSilvrMini Nov 14, 2005 09:19 PM
same thing happen to me and i had to use the "fist" fix it until i finally got the window motor replaced on the driver side. no biggie it was covered under warranty and all is good now. :thumbsup:
fred3 Nov 15, 2005 02:29 AM
It's not a common problem...
7) :razz:
it's just that those that don't have the problem don't post that they don't. So it only appears that way. Oh, I don't have the problem. :grin:
xianqi Nov 19, 2005 01:54 PM
Actually, my 2003 is on its 3rd drivers side window motor... The last time i was in, the customer service advisor told me that they get several window motor repairs a week at the dealership.
