R56 First Check Engine Light NON S
Old Sep 24, 2012 | 10:29 AM
shorenetworks's Avatar
shorenetworks
So while down in VA for work last week I got a check engine light.
Symptoms are
1. Rough idle
2. Missing at random under load
3. Cooling Fan runs constantly
busted out the scan gauge at home and came up with codes
1. P0117
2. P0128
Car is at Mini of Mt Laural right now and there saying a recall was just issued last week for the cooling system?
Any one besides me have this issue ? I searched over the weekend and came up with nothing.
FYI car is a 2011 Cooper HT base manual with 46K miles
Starting to rethink the extended warranty
Old Sep 25, 2012 | 07:24 AM
shorenetworks
Gotta call from the dealer last night,
Car is still in the shop with a random misfire
plugs have been changed and the issue is still occurring?
Love this car but problems like this @ 46K have me very concerned
Part of the reason for passing up on the S was to avoid the mechanical issues.....
Old Sep 25, 2012 | 08:14 AM
strobeyprobey's Avatar
strobeyprobey
Sounds like the coolant temp sensor (fan running constantly) could be the problem.
Old Sep 25, 2012 | 10:39 AM
sean5294's Avatar
sean5294
My car has had this problem since day 1. Seems to be fine now after the fix.
Old Sep 25, 2012 | 10:45 AM
shorenetworks
Just got a call back....
The timing issue/misfire seems to be the timing chain jumped a tooth or two!!!!
Has anyone heard of the base motor having a timing chain issue?
I am getting a really bad fealing about this
Old Sep 25, 2012 | 10:59 AM
Bigprfed22's Avatar
Bigprfed22
Game over man!
Old Sep 25, 2012 | 11:04 AM
Bigprfed22's Avatar
Bigprfed22
You check to see if you have any leaks post maf?
Old Sep 25, 2012 | 12:49 PM
Slave to Felines's Avatar
Slave to Felines
Ouch, a jumped timing chain is not good! And it pretty much says the SA at my local dealer is wrong when he told me that the Justa motors (2011+) didn't have timing chain issues.
Very curious to hear any possible root cause on this problem!!!
Old Sep 25, 2012 | 12:52 PM
strobeyprobey
It is possible as the chain tensioner is oil pressure based. If there was ever a condition where the car was very low on oil or an air bubble decided to get into the tensior, the slack in the chain could have allowed a skip. Twice my non-S had the death rattle (timing chain grinding) for about 40 seconds.
Also the non-S engines had a few reports of being destroyed by the vacuum pump seizing.
Old Sep 25, 2012 | 01:46 PM
shorenetworks
Oil is checked once a week due to driving 700+ miles per week,
And is changed every 8K.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
