Suspension Preload on BC COs for Street Use ONLY
Old Sep 18, 2012 | 09:13 PM
SpeedRacer0212's Avatar
SpeedRacer0212
I am getting an import shop to readjust preload and ride height. I don't feel like messing with it myself, so I am letting an import shop take care of it for $100 and 1.5 hrs of my time.
What is a good or the right preload setting for street use only on BC Racing BR Type Coilovers?
Old Sep 19, 2012 | 05:04 AM
Creeve's Avatar
Creeve
http://vimeo.com/28427984#
Old Sep 19, 2012 | 05:13 AM
SpeedRacer0212
I have already seen this video multiple times. Even though I did not say or specify in my post what I am looking for, I can say that I would like ppl to say what they have set their COs at for street use only purposes. This dude just said that 4mm is good for a street or track setup. He does not say this is factory, this is the standard setting for street use.
I would I gauge this when he says that its proper for a street or track setup. Your driving style is different when it comes to street and track.
Old Sep 19, 2012 | 09:04 AM
Creeve's Avatar
Creeve
By factory do you mean OEM? The OEM struts come with a decent amount of preload, but that isn't really relatable.
The video is made by BC Racing and it seems to me they are saying the "standard" across the board is 4mm.
However, the more preload you dial in the less potential for overall travel you have. Travel is definitely something you want to maximize on the street to allow for uneven road surfaces. Therefor I would guess you would want the absolute minimum preload, which is what I have (for different reasons). Probably only equates to 1 or 2mm, really just as little as you need to avoid the springs binding.
Old Sep 19, 2012 | 09:13 AM
COR BLMY's Avatar
COR BLMY
thought we discussed this on the other thread ???
4 or 5 mm will be the best starting point.
Remember that preload also has a relation with dropout and on the street you need some sprung dropout.
preload is also used for corner balancing ... is the shop doing an alignment (front and rear) and are you corner balancing? if you have a passenger in the car 1/2 the time remember to tell them that .
Your preload is also a factor in alignment .
Bottom line, as I said earlier . it is always a compromise of settings.
IQRaceworks
53
Jun 28, 2024 07:29 AM
CooperSharp
Oct 12, 2015 09:21 AM
eMINI of the State
Oct 2, 2015 03:12 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
gnhovis
Sep 28, 2015 04:07 AM
