R56 spark plugs recommendation?
Old Aug 29, 2012 | 09:37 PM
yyj3869's Avatar
yyj3869
i got 07 mini cooper base model, and i think i need to get my spark plugs replaced. I heard that NGK? is the best one but it's kinda hard to find for base model..
any recommendation and links would be very grateful..
Old Aug 30, 2012 | 03:00 AM
daflake's Avatar
daflake
Stock are fine, you don't need anything up rated for a justa.
Old Aug 30, 2012 | 03:13 AM
mini on's Avatar
mini on
Amazon
Old Sep 1, 2012 | 06:43 AM
33EJB's Avatar
33EJB
Beru 12ZR6SP03
Amazon Amazon
____________________________________________
Old Sep 6, 2012 | 08:55 AM
Mr.Cooper's Avatar
Mr.Cooper
NGK Laser Iridium
Does anybody knows what is the gap for the NGK Laser Iridium Spark plugs
I also notice when I removed the coils that one is like a little bit brownish
for a lack of a better explanation it looks a little rusted, is that normal.
Old Sep 7, 2012 | 07:49 PM
Sirnice's Avatar
Sirnice
According to the Amazon search tool It does not fit.
"This product does not fit your 2007 Mini Cooper
See similar products that fit this vehicle"
I end up purchased these, hope it fits.
NGK (5992) ILZKBR7A-8G
Amazon Amazon
Originally Posted by 33EJB
Beru 12ZR6SP03
http://www.amazon.com/Beru-AG-W0133-...ype=automotive
Old Sep 7, 2012 | 08:45 PM
33EJB's Avatar
33EJB
Curious... today I installed those exact BERU plugs mentioned in my first post in my '08 Cooper. They fit and worked perfectly, as they should as they are identical to the original equipment plugs. The Amazon search tool indicates that the BERU plugs will fit an '07 - I just tried it again to double-check.
My MINI Cooper is a 2008 base model hatchback. I was responding to the OP's request for a recommendation and link to a source for plugs. The OP also has a base-model Cooper, albeit an '07.
Perhaps yours is a convertible - they take a different spark plug, as they use the single-cam engine from the previous generation (R53 et al) MINIs.
Old Sep 7, 2012 | 09:16 PM
Sirnice's Avatar
Sirnice
You are correct. I have convertible selected instead of hardtop. The BERU will fit. I have the 2007 Base hardtop.
Interesting that Amazon search tool also show the NGK (5992) ILZKBR7A-8G will fit (which I ordered). But the gap is .032 instead of .039 (OEM). I guess I can adjust it when I get them. I hope the threading will fit.
Old Sep 8, 2012 | 06:58 AM
33EJB's Avatar
33EJB
I'm quite sure the NGKs will fit & work just fine. I have used NGK plugs in several other cars (including my 1969 MGB), they are a quality product and I have never had an issue with them.
Be very careful adjusting the gap - the center electrode is a very fine wire, really easy to damage. At ~$15 a pop, you don't want to be breaking them!
Old Sep 8, 2012 | 07:26 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Here are the correct ones for R56
http://www.waymotorworks.com/spark-p...-cooper-s.html
Old Sep 8, 2012 | 09:29 AM
33EJB's Avatar
33EJB
Originally Posted by WayMotorWorks
Those are for the "S" and JCW... no love for the Justa?
The Beru 12ZR6SP03 were in my Cooper base hatchback as delivered new from the factory. I just replaced the originals with the same part.
______________________________________________
Old Sep 8, 2012 | 03:35 PM
Sirnice's Avatar
Sirnice
I just installed these (ILZKBR7A-8G) in my 2007 base hardtop. Fits perfect and runs perfect. The tips on the old spark plugs were worn down quit a bit.
I'm at 50k.
http://www.amazon.com/gp/product/B00...ls_o01_s00_i00
Old Sep 8, 2012 | 04:07 PM
yyj3869's Avatar
yyj3869
thank you guys for providing me good information. I think i might do it by myself. anybody has a link that shows how to do it?..
thanks
Old Sep 8, 2012 | 04:11 PM
Sirnice's Avatar
Sirnice
Easy as 1 2 3. Took me 30min or so (first time).
http://www.totehmoon.com/blog/?p=706
You'll need a 14mm 12point deep 3/8 socket. Amazon link below. Cheaper on eBay (around $15 shipped)
examples:
Amazon Amazon
eBay
http://www.ebay.com/itm/BMW-Spark-Pl...#ht_764wt_1043
thanks
Old Sep 8, 2012 | 04:27 PM
DOC4444's Avatar
DOC4444
Minimania lists two Beru plugs for the R56 Justa, one forr those built before Sept of 2009 and one for those after that date. Of course, they never list part numbers.
So is a 12ZR6SP03 the right one for a 2010 Justa?
DOC
Old Sep 8, 2012 | 05:51 PM
33EJB's Avatar
33EJB
DOC
This is copied from Amazon's website. (I had to reformat it to make it readable...)
Compatibility Chart
Beru 12ZR6SP03
Make Model Year Trim
Mini Cooper 2007 Base
Mini Cooper 2008 Base
Mini Cooper 2009 Base
Mini Cooper 2010 Base
Mini Cooper 2011 Base
Mini Cooper 2008 Clubman
Mini Cooper 2009 Clubman
Mini Cooper 2010 Clubman
Mini Cooper 2011 Clubman
I did a quick "google" of some other websites - they all seem to agree, all '07 - '11 MINI Cooper hatchbacks & '08 - '11 Clubmans (Clubmen?) with the base engine use this same plug.
** this is info that I found while researching correct fitment of spark plugs for my own MINI. If you're not sure about fitment in your specific car - check with your vendor before you purchase anything.**
Old Sep 8, 2012 | 06:53 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
I would not trust the various purported "applications" of a spark plug by some geek loading an ad into Amazon OR ebay or that matter. Double and triple check all your part numbers.
A guy here once picked up a set of plugs that way which were too long, not the correct ones, and punched holes thru his pistons.....
Old Sep 8, 2012 | 06:55 PM
DOC4444's Avatar
DOC4444
Found what I was looking for. Mini of Atlanta says that one is for production up to 9 of '09: http://parts.miniofsouthatlanta.com/...120035933.html
They say 12ZR6SP02 is for production after 9-'09 .
DOC
Old Sep 8, 2012 | 07:08 PM
DOC4444's Avatar
DOC4444
See Pelican as well:
http://www.pelicanparts.com/catalog/...Elignt_pg1.htm
So, is there a significant difference between the "02" and "03"? (Rather a huge price differential.)
DOC
Old Sep 8, 2012 | 07:27 PM
33EJB's Avatar
33EJB
Who cares what you would trust?
I'm just sharing some info that I discovered recently when trying to buy the proper part for my car. The OP asked a question... I responded. I'm not "some geek loading an ad into ebay". I included part numbers in my posts so that anyone interested could easily double and triple check their specific application.
Maybe the guy who put in the wrong plugs and blew holes through his pistons should have paid some attention to threads like this one. All we're doing here is trying to help each other avoid idiotic mistakes like that.
Old Sep 9, 2012 | 05:04 AM
daflake's Avatar
daflake
You kinda just made GR's point.
Old Sep 9, 2012 | 06:02 AM
-=gRaY rAvEn=-
Moderator
Yup, skim reading and not bothing to read what I wrote word for word......
Old Sep 9, 2012 | 06:21 AM
-=gRaY rAvEn=-
Moderator
This comes to mind...
Old Oct 9, 2012 | 04:13 PM
aznqtboy984's Avatar
aznqtboy984
Just changed the spark plugs on my wife's car. The old plugs are very brown and rusty looking. They also seem to have some carbon at the tip as well. My wife's car has 55k. I recommend changing them sooner than 60k.
Old Sep 11, 2013 | 02:29 PM
kyoo's Avatar
kyoo
so... this will work for an 08 base mini hatch?
Beru Spark Plug : Amazon.com : Automotive Beru Spark Plug : Amazon.com : Automotive
