R56 Weird clicking sound from 09 MCS
My 09 MCS recently started to develop a clicking type noise when I make left hand turns at slow and highway speed. If I turn the wheel about 10-20 degrees and hold it I can hear the noise come from the drivers side of the car. The car currently only has 13k miles on it so I am kind of dumbfounded as what it could be.
My only guess is possibly a bad axle?
Is the tire rubbing on the wheel liner? It also could be a bad wheel bearing. When the front axles went bad on my 01 325xi they would click when turning or make a high pitch whining noise at highway speeds.
its a metal clicking sound. I called my local mini dealers service department to see if it is but I had to leave a message. I bought the car used but bought a warranty for it but hopefully its still under the factory one so I dont have to pay anything.
This happened on our Toyota Camry when it was less than 1 year old. Had only 6k miles on the car ...we had to replace it at OUR expense. I was so pissed! -cost us about $750 or $800 from what I remember. Toyota's reasoning was that we didn't rotate the tires at 5k miles!!! -we only went over by 1k miles.. that was such BS.
Anyway, that car caused us a lot of headache ..and fortunately we no longer own it.
Hopefully MINI will treat that as an under warranty item.
With only 13k miles I really would like to doubt the wheel bearings are bad. My only experience with a failed wheel bearing is a constant grinding noise.
With only 40k on my clock I had a clicking during left hand turns. First things first, check the torque specs on the lugs. Mine where off by almost 15 ft-lbs each.
Have them re-torqued to 103 ft-lbs. Solved my problem. Eliminate the easy stuff.
Well I literally feel extremely dumb. I took the car last week to get new tires put on and apparently the shop I took the car to didnt torque them down properly. I came home and took off my lug nut cover and 3 of the studs I could turn with my hand for multiple turns. really scary that only one of the studs was at least hand tight. I should have checked them my self after i got the car back but I have been quite busy this week. thanks for the help guys.
Wait, that reminds me - maybe you don't have studs!
Sorry, I didn't chime in for fun... I have the clicking sound too but I was thinking it was the end link.
R50/53 Replacement AC compressor??
PrimePower
Aug 16, 2015 06:29 PM
Aug 12, 2015 01:24 PM
