Suspension Aftermarket rear swaybars
Hi MINIacs,
I had an aftermarket rear sway bar installed on my 05 MCS about 5 years ago. It now needs replacement bushings. At the time, it was 'THE' upgrade sway bar to use.
Can anyone give me some brands of aftermarket sway bar so that it might jolt a memory of which one I have, and therefore which replacement bushings to order?!
Thanks all, Happy Motoring.
Thanks - I asked because the garage where they found that the bushings are worn told me that they didn't know where to find the correct replacements, so I figured that I would have to find out the correct brand and replacements.
Waymotorworks can source them for you. He'll probably try to sell you the very nice h-sport brackets with poly bushings that have a zerk fitting so you can grease them (though a properly installed bar with greased bushings and/or teflon tape won't need them, it's nice to have). You should measure your swaybar diameter just to be sure what you need. It's probably a 19mm.
- drew
- drew
Do you know the color?
Alta is red...
Ireland eng is blue..
Most others are black/dark grey...
H-SPORT,.
H&R
..TSW (texas speed works((now owned by waymotorworks))
Heck many others...diameter is important...18, 19, 20. Even 25 mm hollow bars are around...
Alta is red...
H-SPORT,.
H&R
Are you the Zippy who used to have Zippity??
I'm the Jolly who still has ZipMore!!!
Thanks for the help guys, I really appreciate it.
Is a rear sway bar really a big improvement? Maybe I'm not driving it hard enough lol but I don't feel the need for an upgrade. What changes if I do go for it?
Just kidding, I'm on the second hole, didn't tried the last one as I'm pretty happy with how it handle.
Thanks very much - I will take a photo as best I can of the bar tomorrow.
I guess it uploaded as a thumbnail on my post, but if you click on it, you can see it bigger.
Could it be an H-Sport?
If so, which bushings should I order?
Thanks again for the help guys.
that is def an Hsport comp rear sway bar. Here are the bushings you need:
http://www.waymotorworks.com/swaybar-bushing-set.html
Select the 25.5mm set and you'll be good to go.
Thank you SO much.
Ordered!!
ClayTaylorNC
Aug 10, 2015 09:19 PM
