R56 Bentley manual lets me down!
Old Aug 12, 2012 | 11:05 AM
RSchleder's Avatar
RSchleder
I own a 2007 Mini S and need to replace my LOWER grille due to some damage. I have the Bentley Service Manual for my car, however. there is no info on changing the lower portion of the grille. There's info on the top portion (called radiator grill), but the info on the bottom portion is absent for some reason. What is the process to perform this task? Do I need to remove the bottom of the front bumper cover to get at the lower grille attachment points? Any info will be greatly appreciated. Thanks in advance for your helpful posts. Ron
Old Aug 12, 2012 | 11:50 AM
slinger688's Avatar
slinger688
When I do grill and IC work, I usually take off the bumper. Not sure if that is necessary but it gives me lots of space to work with.
See helix13.com for their instructions to remove the front bumper (for IC install but don't take off the IC). Not too difficult and it took less than 2 hours the first time I did it.
Old Aug 12, 2012 | 12:10 PM
RSchleder's Avatar
RSchleder
Thanks slinger. If there's a way to do it without removing the front bumper, that would be my preference. anyone else?
Old Aug 12, 2012 | 12:20 PM
rkw's Avatar
rkw
The bumper must be removed. Look at bumper instructions in the Bentley, and the grill instructions will probably be in that section as well.
Meanwhile, attached are instructions from the BMW TIS manual.
File Type: pdf
Old Aug 12, 2012 | 01:06 PM
countryboyshane's Avatar
countryboyshane
Just take off the front bumper cover and the clips that hold in the lower grille will be easily accessible.
Old Aug 12, 2012 | 01:17 PM
Porthos's Avatar
Porthos
The bumper takes about 5 minutes to take off and yes you have to take it off.
Old Aug 12, 2012 | 02:56 PM
RSchleder's Avatar
RSchleder
Thanks guys, that really helps. I appreciate all the info and help. Have a great week everyone. Ron
Old Aug 12, 2012 | 03:35 PM
slinger688's Avatar
slinger688
I have done it 4-5 times already and it still takes me longer than 5 minutes. In fact it takes me more than that that jack up the car and put the front on jack stands and take the front wheels off. This could be Olympic and World record, just keeping with this week's theme.
Old Aug 12, 2012 | 05:25 PM
rkw's Avatar
rkw
You do that for taking the bumper off? It shouldn't be necessary.
Old Aug 12, 2012 | 06:36 PM
Porthos's Avatar
Porthos
That's your problem. You don't need to to jack it up nor take the wheels off.
Old Aug 12, 2012 | 06:49 PM
slinger688's Avatar
slinger688
I have to since it is lowered and I cannot get to the screws inside the wheel well. Lowered, running fatter tires and spacers do not give me much room to maneuver.
Old Aug 12, 2012 | 06:50 PM
slinger688's Avatar
slinger688
Maybe we can see a live feed of you doing that in 5 minutes. I bet I could learn a few tricks.
Old Aug 13, 2012 | 05:26 AM
Porthos's Avatar
Porthos
I haven't done it in so long that it probably would take me about 10 to 15 to do it. Plus you are going to wait on the feed for awhile as my car is 3k miles from me.
elverado
Jan 18, 2022 02:51 AM
vetsvette
Sep 21, 2015 01:19 PM
The_Kid
Sep 17, 2015 01:51 AM
Filmy
Sep 7, 2015 08:27 PM
Sep 4, 2015 08:25 AM
