R56 R56 cigarette lighter problems
Old Jun 9, 2012 | 10:11 AM
Bosco32's Avatar
Bosco32
I installed a parrot ipod B/T unit, I tied it into the cigsrette lighter wiring. It worked great. After a week it would just stop working at random and then restart. Then finally it will not work at all. After removing the parrot unit any device I plug into the lighter will not work(but the LED on the plug still works). The fuse is still good at the fuse box. When I check the lighter wiring, under any load the voltage drops to zero. The outlet in the rear works fine. Any suggestions?
Old Jun 10, 2012 | 06:51 AM
bluefox280's Avatar
bluefox280
Have you confirmed all the wiring back to the fuse block?
Have you confirmed electrical continuity through the fuse block to the grounding point for the lighter?
Sounds like a loose connection more than anything since a short-to-ground issue would have caused a fuse to pop.
- Erik
Old Jun 13, 2012 | 09:31 AM
Bosco32's Avatar
Bosco32
Thanks for the feed back. The wiring back to the ground and fuse will be my next project.
cornfly888
Aug 24, 2015 09:57 AM
Shane Wendel
Electrical
Aug 20, 2015 06:50 AM
milkrun49
Factory JCW Talk (2009+)
Aug 13, 2015 06:01 AM
Aug 12, 2015 01:24 PM
