Pics: 19" Wheels on Countryman.
Old Jun 4, 2012 | 09:48 AM
TDNparts's Avatar
TDNparts
Thumbs up Pics: 19" Wheels on Countryman.
Looks to see pics of Countrymans on 19" rims.
Aiming to compile all 19" CM pics here as I have run across only a few in random links to other threads.
I ordered my Countryman ALL4 w/ the factory 17" A/S RF. Figure I'll use these in the winter & during spring pot-hole season.
I'm really considering a 19" as I know I will be upgrading to at least 18" rims in the near future.
I am well aware of the ride quality, unsprung weight, acceleration etc.
I just think the 19" fit the body/look very well.
If you are posting pics &/or feedback of your CM w/ 19's. Please state if it also has the factory Sport Suspension, or any aftermarket springs.
(*if possible, width, offset, tire size, use of spacers would also be greatly appreciated) TIA.
Old Jun 4, 2012 | 02:07 PM
bentyyc's Avatar
bentyyc
Here's a few for ya...
http://www.flickr.com/photos/bentyyc/6212552769/
http://www.flickr.com/photos/bentyyc/6175364680/
http://www.flickr.com/photos/bentyyc/6138439286/
http://www.flickr.com/photos/bentyyc/6138430864/
Old Jun 4, 2012 | 07:10 PM
aforalbert2002's Avatar
aforalbert2002
-factory Suspension
-19" 8.5j ET42
Old Jun 7, 2012 | 07:32 AM
juannicolas's Avatar
juannicolas
Originally Posted by aforalbert2002
-factory Suspension
-19" 8.5j ET42
Hello, that CM looks killer.
Could you tell me what tire specs is using there?
I was about to bye the same rims/specs but tires I'm not so sure what size should work for me, I don't want mine to be rubbing when putting weight on the back. I will appreciate your input. Thanks
Old Jun 7, 2012 | 09:13 AM
MotoGreg's Avatar
MotoGreg
That is not my white car in the pic, but I have the same size wheels (19x8.5+42) and I'm using Bridgestone Potenza RE760 Sport in size 245/40/19.
Old Jun 7, 2012 | 09:22 AM
juannicolas
Thank you for the response.
Do you have suspension kit?
Does yours have any type of rubbing at any point? even with wheight in the back?
Old Jun 7, 2012 | 10:52 PM
MotoGreg's Avatar
MotoGreg
No rubbing issues. The tire diameter is only 3% more than stock. Suspension is stock right now, I actually have a set of NM lowering springs but haven't had a chance to put them on yet.
Old Jun 8, 2012 | 05:21 AM
juannicolas
Great thanks, I havent found rims with offset of 38 or 42 where i live. But i do have available 35 and 45 would you mind to give me your opinion of expertice here? What offset should ill go for to me sure no rubbing ocurs?
Old Jun 8, 2012 | 08:23 AM
MotoGreg's Avatar
MotoGreg
Assuming you're talking about an 8.5" wide wheel, then 45 should be okay, it's only 3mm more inward than my 42.
The 35 is going to stick out past the fenders a bit and not look as good.
Old Jun 8, 2012 | 08:46 AM
juannicolas
Sorry, yes they are 19x8.5
I was about to buy this ones
http://tenzoracingsports.com/wheel05.htm
Black Matt
Old Jun 8, 2012 | 05:38 PM
MotoGreg's Avatar
MotoGreg
They don't show that wheel in a 5x120 bolt pattern on their fitment chart. It looks like the only wheel they offer in 5x120 bolt pattern, size 19x8.5, with correct offset, is the Concept-10 in either Matte Black, Hyperblack, or Machined.
On my '05 Cooper S I had 18" Tenzo Mach-10 wheels that looked really good on the car, but they don't make those anymore.
Old Jun 8, 2012 | 05:40 PM
juannicolas
You can see it here
http://tenzoracingsports.com/prices.htm
Old Jun 8, 2012 | 05:47 PM
MotoGreg's Avatar
MotoGreg
Ya, that's where I looked. 5x100, 5x112, or 5x114.3 only... not showing 5x120.
Old Jun 8, 2012 | 05:55 PM
juannicolas
The Concept-10
Old Jun 8, 2012 | 06:00 PM
MotoGreg's Avatar
MotoGreg
Got it. Your original link was to the Type-M, so I thought that was the wheel you wanted.
Old Jun 8, 2012 | 06:01 PM
juannicolas
Oops sorry for that :P
Old Jun 8, 2012 | 06:39 PM
aforalbert2002
rubbing issue never happen in my case as i'm using stock springs.
I use 42 for both front and rear, i find it is perfect fit to the front, but for the rear, there are space for moving outward a bit.
I saw ppl using 35 for both front and rear in this forum. (You can do some search and see the outcome.)
so I would recommend u 45 for the front and the rear, or try a 35 for the rear.
For the tire i use michelin PSS 225/40/19.
here ac-schnitzer for your reference.
http://www.ac-schnitzer.de/en/mini/p...an-r60/wheels/
Old Jun 8, 2012 | 06:56 PM
juannicolas
I appreciate all your help and time. Thank you so much.
Old Jun 12, 2012 | 04:55 PM
kconner5's Avatar
kconner5
Here are my new 19" Elbrus I08's... They are a replica E92 M3 wheel.
Old Jun 13, 2012 | 09:57 AM
shark715's Avatar
shark715
Sweet! Kyle, are those the anthracite mach with ice coating? Where did you buy them?
Old Jun 13, 2012 | 10:08 AM
kconner5's Avatar
kconner5
Thanks!
They're Elbrus I08's with ice coating and I got them on TireRack
Kyle
Old Jun 13, 2012 | 10:27 AM
DooBahDoo's Avatar
DooBahDoo
We're running Drag DR37 19x8.5's with Nitto Neo Gen 245/35ZR19 set-up from Discount Tire on our All-4.
Old Jun 13, 2012 | 10:51 AM
TDNparts's Avatar
TDNparts
are you guys looking under AWD(xi) BMW models for the rim offerings on the rack/discount tire etc?
I'm looking at the Axis XMX Matte Grey for my LW/Blk CM
there were not a lot of great looks, I know the non staggered BMW stuff can fit(some might require rings?) & likely has a ton more variety.
Old Jun 13, 2012 | 11:22 AM
frstrtdmac's Avatar
frstrtdmac
Why don't you post some pics!!!
Old Jun 13, 2012 | 11:28 AM
TDNparts's Avatar
TDNparts
anyone here on 19's & lowered?
