xxr 527s!
Old Mar 19, 2012 | 09:26 AM
G0LDENDOMER's Avatar
G0LDENDOMER
xxr 527s!
Just put some xxr 527's on my car! 17x8.25 +25
I need to work some magic in the back though. I've rubbed through the plastic and now I think I'm actually hitting metal :l
ps, sorry for the cell phone picture, I'm working on getting some better ones!
Old Mar 19, 2012 | 01:51 PM
rum4's Avatar
rum4
Is the car lowered any? If so how much and on what setup?
Old Mar 19, 2012 | 03:33 PM
G0LDENDOMER
I'm on megan coilovers with hsport control arms. In the picture, the front and back are both down all the way. This afternoon, I raised the back end about 1/4 of an inch to get rid of my rubbing problems.
Old Mar 19, 2012 | 03:37 PM
Mini PoWA!'s Avatar
Mini PoWA!
Love the red nuts with the black wheels
Old Mar 19, 2012 | 04:09 PM
rum4's Avatar
rum4
watch it, he likes your "red" nuts! LMAO
Glad you got it cleared for no more rubbing.
Old Apr 4, 2012 | 06:15 AM
rum4's Avatar
rum4
You got any pics of the car from the front to rear that show if they are tucked or poking? What size tire are you running on the rims?
Old Apr 4, 2012 | 06:52 AM
G0LDENDOMER
Here are a couple more, the tires are 205/40/17
Old Apr 4, 2012 | 07:32 AM
srtoad4's Avatar
srtoad4
What did you use for the stud conversion?
Absolutely LOVE the wheels!! More pics!!
Old Apr 4, 2012 | 09:28 AM
G0LDENDOMER
thanks srtoad! it's just a cheap ebay conversion with sickspeed tuner lugs
here are a few more pictures
Old Apr 4, 2012 | 09:50 AM
rum4's Avatar
rum4
Goldenomer, thanks for the pics. I am looking at getting the same wheel in chromium black for my white silver clubman. I just needed to see if the top of the wheel was tucked or poked. Thanks for showing me my answer. Also did you have to do anything with the camber or toe?
Old Apr 4, 2012 | 09:51 AM
srtoad4's Avatar
srtoad4
Can you post a link to the stud conversion? There are tons of different kinds online.
Thanks again man, cars looking awesome with those 527's.
Old Apr 4, 2012 | 03:49 PM
G0LDENDOMER
@rum, i run about -2 degrees of camber, but i'm also lowered so if you're at stock height, you should be fine
@srtoad, here is the link http://www.ebay.com/itm/20-PCS-BMW-5...12d55d&vxp=mtr
i got those and the lug nuts are just generic 12x1.5 tuner lugs
Old Apr 4, 2012 | 03:53 PM
rum4's Avatar
rum4
Thanks Goldenomer
Old Aug 21, 2012 | 12:10 PM
MiniAJ's Avatar
MiniAJ
What's the probability of failure of the conversion kit and lugs falling out while driving wanted to get it done for my car but was scared of a rim falling off on the turnpike.
Old Aug 21, 2012 | 12:15 PM
G0LDENDOMER
My original eBay kit failed. I had two lugs snap clean at the hub, but I was lucky enough to catch it before I lost a wheel. I've since had the TSW kit for almost 4 months with no problems. I've checked them basically once a month and they look as good as ever.
Old Apr 19, 2013 | 06:56 PM
djc2473's Avatar
djc2473
rubbing
I have a 2006 mini jcw on stock suspension and i also have a set of 17x8.25 and its rubbing pretty bad. Its chewing the plastic and tire up havent had it on a alignment rack so im not sure what the camber is set to but considering its stock should be in factory specs. i am running a 215 45 tire tho. trying to figure out how to stop it from rubbing. any help would be grateful.
Old Apr 25, 2013 | 01:39 PM
awm3trantg's Avatar
awm3trantg
wheels look great!!!
Old Apr 25, 2013 | 06:07 PM
afadeev's Avatar
afadeev
First of all, the alignment hasn't changed one bit by swapping wheels or tires (unless you radically changed the rolling diameter), so don't worry about camber.
Secondly, why would you put such a narrow tires on such a wide wheel?
215mm wide tires belong on 7"-8" wheels: http://www.tirerack.com/tires/tires....omCompare1=yes
Is it rubbing on the inside of the wheel well or the strut? If yes, then you have too large of an offset (what is the offset?) --> this can be cured by adding spacers to push the wheel back out away from the center line.
If the rubbing is on the outside (fender), your only remaining choices are to either ditch the wheels/tires, or to raise the ride height above the edge of the fender. Considering the suspension is stock, this would get ugly.
HTH,
alex
Old Apr 25, 2013 | 06:34 PM
yaphetlives's Avatar
yaphetlives
^ You could also cut a 10-15mm section of the metal arch away this is covered by the plastic arches, so it's completely unnoticeable as the plastic arch hide the damage to the naked eye. Some guys on m/u and MT have done this when running more radical offset wheels.
Old Apr 29, 2013 | 08:46 AM
awm3trantg's Avatar
awm3trantg
did you have to run any type of hubcentric rings or are these wheels hubcentric already?
I am hoping to run these wheels and sizes with 205/45/17 tires
lowered on BavAuto sport springs. and ill do the oem camber as much as possible, i just dont want any rubbing issues
Old Apr 29, 2013 | 09:01 AM
afadeev's Avatar
afadeev
That is an absurd price to pay for installing wheels with wrong (too small of an) offset for your Mini.
Sell the wrong wheels on eBay, buy the proper wheels, and you will have no problem fitting 215 or 225 wide tires !
alex f
Old Aug 28, 2016 | 09:54 PM
burble_durble's Avatar
burble_durble
I was looking at the 17x7.5 et40 wheels.
I was looking at the 17x7.5 et40 to get as close to OEM as I could. I was thinking of the scrubbing against the fender flares.
Do you guys think that this narrower size will still look good? Or should I take the chance and go with the 7x8.25 et25?? This seems to be the choice of many.
I haven't lowered my car at all.
Old Apr 20, 2017 | 08:41 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
This topic was of interest in another tread so check it out.
Old Apr 24, 2017 | 10:34 AM
elijahallmond's Avatar
elijahallmond
what year is yours and what size wheels/tires/off set is that
Old Apr 25, 2017 | 01:00 PM
minihune's Avatar
minihune
The member that was asking is-
elijahallmond
SOOPER_S
Jul 26, 2016 01:03 PM
trabbledot
Tires, Wheels, & Brakes
Aug 14, 2014 11:17 AM
Mr. Krisztian
Sep 13, 2012 09:23 PM
MiniAJ
Aug 25, 2012 12:10 PM
Ed.
Nov 14, 2011 08:26 AM
