xxr 527s!
1 Attachment(s)
Just put some xxr 527's on my car! 17x8.25 +25 :thumbsup:
Attachment 170932 I need to work some magic in the back though. I've rubbed through the plastic and now I think I'm actually hitting metal :l ps, sorry for the cell phone picture, I'm working on getting some better ones! |
Is the car lowered any? If so how much and on what setup?
I'm on megan coilovers with hsport control arms. In the picture, the front and back are both down all the way. This afternoon, I raised the back end about 1/4 of an inch to get rid of my rubbing problems.
Love the red nuts with the black wheels :thumbsup:
Originally Posted by Mini PoWA!
(Post 3474923)
Glad you got it cleared for no more rubbing. |
Originally Posted by G0LDENDOMER
(Post 3474681)
http://i1135.photobucket.com/albums/...52398382_n.jpg I need to work some magic in the back though. I've rubbed through the plastic and now I think I'm actually hitting metal :l ps, sorry for the cell phone picture, I'm working on getting some better ones! Thanks |
3 Attachment(s)
Here are a couple more, the tires are 205/40/17
Attachment 170933 Attachment 170934 Attachment 170935 |
What did you use for the stud conversion?
Absolutely LOVE the wheels!! More pics!! |
4 Attachment(s)
thanks srtoad! it's just a cheap ebay conversion with sickspeed tuner lugs
here are a few more pictures ;) Attachment 170936 Attachment 170937 Attachment 170938 Attachment 170939 |
Goldenomer, thanks for the pics. I am looking at getting the same wheel in chromium black for my white silver clubman. I just needed to see if the top of the wheel was tucked or poked. Thanks for showing me my answer. Also did you have to do anything with the camber or toe?
Can you post a link to the stud conversion? There are tons of different kinds online.
Thanks again man, cars looking awesome with those 527's. |
@rum, i run about -2 degrees of camber, but i'm also lowered so if you're at stock height, you should be fine
@srtoad, here is the link http://www.ebay.com/itm/20-PCS-BMW-5...12d55d&vxp=mtr i got those and the lug nuts are just generic 12x1.5 tuner lugs |
Thanks Goldenomer
What's the probability of failure of the conversion kit and lugs falling out while driving wanted to get it done for my car but was scared of a rim falling off on the turnpike. :sly:
My original eBay kit failed. I had two lugs snap clean at the hub, but I was lucky enough to catch it before I lost a wheel. I've since had the TSW kit for almost 4 months with no problems. I've checked them basically once a month and they look as good as ever.
rubbing
I have a 2006 mini jcw on stock suspension and i also have a set of 17x8.25 and its rubbing pretty bad. Its chewing the plastic and tire up havent had it on a alignment rack so im not sure what the camber is set to but considering its stock should be in factory specs. i am running a 215 45 tire tho. trying to figure out how to stop it from rubbing. any help would be grateful.
wheels look great!!!
Originally Posted by djc2473
(Post 3723302)
Secondly, why would you put such a narrow tires on such a wide wheel? 215mm wide tires belong on 7"-8" wheels: http://www.tirerack.com/tires/tires....omCompare1=yes Is it rubbing on the inside of the wheel well or the strut? If yes, then you have too large of an offset (what is the offset?) --> this can be cured by adding spacers to push the wheel back out away from the center line. If the rubbing is on the outside (fender), your only remaining choices are to either ditch the wheels/tires, or to raise the ride height above the edge of the fender. Considering the suspension is stock, this would get ugly. HTH, alex |
^ You could also cut a 10-15mm section of the metal arch away this is covered by the plastic arches, so it's completely unnoticeable as the plastic arch hide the damage to the naked eye. Some guys on m/u and MT have done this when running more radical offset wheels.
did you have to run any type of hubcentric rings or are these wheels hubcentric already?
I am hoping to run these wheels and sizes with 205/45/17 tires lowered on BavAuto sport springs. and ill do the oem camber as much as possible, i just dont want any rubbing issues |
Originally Posted by yaphetlives
(Post 3726825)
Sell the wrong wheels on eBay, buy the proper wheels, and you will have no problem fitting 215 or 225 wide tires ! alex f |
I was looking at the 17x7.5 et40 wheels.
(Post 3474681)
http://i1135.photobucket.com/albums/...52398382_n.jpg I need to work some magic in the back though. I've rubbed through the plastic and now I think I'm actually hitting metal :l ps, sorry for the cell phone picture, I'm working on getting some better ones! Do you guys think that this narrower size will still look good? Or should I take the chance and go with the 7x8.25 et25?? This seems to be the choice of many. I haven't lowered my car at all. |
This topic was of interest in another tread so check it out.
what year is yours and what size wheels/tires/off set is that
Originally Posted by elijahallmond
(Post 4296989)
elijahallmond |
