R50/53 Squealing Brakes-Cannot Figure it out
Old Mar 8, 2012 | 11:56 AM
weewass's Avatar
weewass
I apologize in advance If I've missed this post somewhere else, however I've just replaced the front rotors and pads on my 03 mcs with stock rotors and minted extreme pads. They will not stop squealing! I even took them off and applied CRC disk brake quiet to the back but no luck. Any ideas?
Old Mar 8, 2012 | 12:49 PM
BRGPA's Avatar
BRGPA
Did you follow the standard procedure to bed the new pads? Also, I'm not familiar with the pads you installed, but some high performance pads are known to squeal. Race type pads can make lots of noise, but in those applications all the driver cares about is stopping power not noise.
Old Mar 8, 2012 | 12:58 PM
weewass's Avatar
weewass
yes, bedded, everything was done correctly. These aren't considered high performance pads I don't think
Old Mar 8, 2012 | 02:58 PM
Capt_bj's Avatar
Capt_bj
some pads will make noise for as much as 1000 miles as they bed (quick bed applies to race prep' not everyday driving)
Old Mar 8, 2012 | 02:59 PM
proximo's Avatar
proximo
Make sure you put the quiet stuff on any surface of the pad that could possibly touch the caliper. Back and sides (including the notch where it fits into the caliper). I forgot if ours has it (I've slept since I changed them), but on my Challenger, there is a little aluminum clip that fits between the caliper and pad in that little notch that if it's not also coated, I get a slight squeal.
Old Mar 8, 2012 | 03:36 PM
weewass's Avatar
weewass
Ok thanks for the tip. I was sure I covered everything but maybe just the back of the pads. I'll try to take them back off and cover the sides as well. Just don't want to get any on the pads. Could it just be the material that the pads are made of?
Old Mar 8, 2012 | 03:39 PM
proximo's Avatar
proximo
Yes, it could be the material and just needs to bed in as the others have noted. Which pads did you use? I put Hawks HPS on ours and they have a short "sound" (not a squeal, not heard outside the car) just before full stop that goes away after they've warmed up.
Old Mar 8, 2012 | 03:41 PM
weewass's Avatar
weewass
They're Mintex Xtreme Pads. Got them from Bavauto
Old Mar 8, 2012 | 03:46 PM
proximo's Avatar
proximo
I have heard, but don't quote me on this, that those can squeal for a long period of time (I've read up to a ~5000 miles). That's not cool.
Old Mar 8, 2012 | 03:47 PM
weewass's Avatar
weewass
:arghhhh
Old Mar 12, 2012 | 12:18 PM
weewass's Avatar
weewass
I believe I've fixed it. I took the brakes back off this weekend and somehow it looks like the disc brake quiet got pushed around the outside of the pads instead of the part contacting the calipers. I heard a tip that if you use grease it works well so I applied more DBQ and then piled grease on top and vualah! no squeals....yet. (crossing fingers). thanks for the help.
scfiveo
Sep 27, 2019 02:27 PM
randeez
Oct 5, 2015 09:23 AM
potterstein
Oct 2, 2015 09:30 AM
dutchhome
Sep 30, 2015 07:17 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
