R50/53 Spring problem rant
Old Jan 25, 2012 | 04:42 PM
Minicoopr50's Avatar
Minicoopr50
Spring problem rant
So I have seen a lot of complaints about the second gen minis "vibrating" at specific rpm"s after installing springs.
Also, I've heard springs make handling worse.
I have ordered Megan control arms and tein springs recently and will be putting them on my r50 soon.
Is there anything I should know before putting these parts on?
Has anyone had similar problems with the r50/53?
Will springs make handling worse?
Thanks!
Old Jan 25, 2012 | 07:02 PM
ZippyNH's Avatar
ZippyNH
One thing to make you aware of...
If you were to order new springs from mini, they would want the list of options...they use this to determine your cars weight....the weight of the options determins the required spring rates...
Aftermarket springs are just aimed at one size fit all...
Lowering with springs is for looks....it reduces suspension travel...somthing the mini already lacks.
If you must lower you car imo, and want handling, coilovers are the way to go...
Jcw springs on gen1 are slightly lower....and would be matched to you car...biggest things that affect weight are sunroof and tranny....
Old Jan 25, 2012 | 07:32 PM
Evasive's Avatar
Evasive
I have hsports on stock shocks with no vibration. Not sure about the handling getting worse although it does change the suspension geometry. Unless you're going to track your car, I doubt it'll really have enough negative impact on handling.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
mikeyb74
Mar 21, 2017 12:30 PM
psmith27616
Suspension
11
Oct 26, 2016 04:57 AM
melscoop
Mar 30, 2016 06:56 PM
PEterChoqu
Aug 26, 2015 08:33 AM
