Suspension Installed lowering springs...back went down front stayed same height.
Old Jan 8, 2012 | 09:01 AM
abadgti's Avatar
abadgti
Installed Koni springs yesterday and for some reason the back went down as expected but the fronts didn't move. Did I do something wrong? I reused everything except for new strut mounts. Should I have cut the bump stops? Please help me!!
Old Jan 8, 2012 | 09:41 AM
Chili_head's Avatar
Chili_head
Sorry, he said koni. Edited.
Old Jan 8, 2012 | 09:45 AM
dannyhavok's Avatar
dannyhavok
A few TSW lowering spring buyers had this issue from a bad batch.
Old Jan 8, 2012 | 10:08 AM
abadgti's Avatar
abadgti
I have Konis. Maybe I should contact them directly.
Old Jan 12, 2012 | 07:22 PM
zachsa's Avatar
zachsa
same here with the h&r stage 2 lowering springs..im amssuming since they are advertised to be 20% stiffer than stock..and they are...they are just to stiff up front to compress under the cars own weight.
looking into an adjustable coilover set.
sorry i was no help but your not alone!!!
good luck
Old Jan 12, 2012 | 09:03 PM
HRM's Avatar
HRM
Some say they do settle over time. It is possible not to have them inserted all the way in the arm too, also if you added camber plates, that is an increase you can't avoid.
Old Jan 15, 2012 | 10:44 AM
nopistons's Avatar
nopistons
I would wait a while to see if it settles. Cutting the bump stops wont change the ride height.
Old Jan 15, 2012 | 11:19 AM
UKSUV's Avatar
UKSUV
Springs can take up to a thousand miles to settle. Its only been a day, give it some time.....
silence2-38554
Nov 12, 2015 09:39 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Minibeagle
Aug 13, 2015 10:00 AM
