R56 Radiator Fan
Old Jan 7, 2012 | 09:18 AM
drsimmons's Avatar
drsimmons
Radiator Fan
Just wondering, up until a few days ago after driving 30 miles or so and stopping (shutting off car), my radiator fan would come on for about 1 minute and shut off. The past 2 days it hasn't come on at all. Engine doesn't feel any hotter than normal and coolant level is up.
My question is, will the car display any CEL if the fan motor isn't functioning???
Temps have been 40's in the morning and around 70 in afternoon.
Thanks in advance.
Old Jan 7, 2012 | 09:49 AM
bluefox280's Avatar
bluefox280
Originally Posted by drsimmons
...my radiator fan would come on for about 1 minute and shut off. The past 2 days it hasn't come on at all. Engine doesn't feel any hotter than normal and coolant level is up.
Depending on the amount of load you put on the engine prior to shut-down will affect if the water temperature is hot enough for the radiator fan to turn on or not.
No; the radiator fan is not apart of the federally mandated OBDII fault codes.
If the radiator fails to operate, you will not see a CEL.
More than likely you radiator fan is a-ok.
The ECU only runs the fan after shut-down if the coolant temperature sensor sees a temp higher than operating temp.
- Erik
Old Jan 7, 2012 | 10:03 AM
drsimmons's Avatar
drsimmons
^^^Thank you for the info. I think I'll run it a little further tomorrow morning and check it. Makes sense about the CEL not displaying, du.
Old Jan 7, 2012 | 11:21 AM
walk0080's Avatar
walk0080
Yes the fan may start up for a few minutes when the engine is warm. My previous justa Cooper did that all the time.
Now with the new JCW, the fan never turns on after I shut the engine off - at least not so far with fall and winter weather. Only the turbo water pump continues to run.
OutMotoring
Mar 3, 2017 06:29 AM
JAB 67
Sep 29, 2015 01:34 PM
kevinlhr310
Sep 27, 2015 02:31 PM
rt808
Sep 25, 2015 01:59 PM
