R56 Secret Compartment/Dash Rattle Fix?
Old Dec 27, 2011 | 11:32 AM
Bmont82's Avatar
Bmont82
Just seeing if any has been able to anti-buzz/rattle their secret compartment in the dash or can point me to some info on it. I plan on removing the parts next weekend and trying to fix it once and for all. I have some foam tape and lots of built up annoyance :-).
Please help if you can, thanks...
Old Dec 27, 2011 | 11:44 AM
chimivee's Avatar
chimivee
Several 3/8" round felt pads around the perimeter worked for me. Didn't need to take anything apart. Requires slightly more force to open the compartment, since the felt must be compressed somewhat.
Old Dec 27, 2011 | 12:16 PM
Porthos's Avatar
Porthos
Ya my compartment is also rattling but, it is the lid itself and not the box behind it.
Old Dec 27, 2011 | 03:13 PM
glangford's Avatar
glangford
I had that problem once. I have the english oak dash and it turned out to be the wood buzzing on the plastic backing. They replaced the whole assembly and when I left it was still buzzing. Drove right back and they stuffed some goo that they use for windshield replacement between the two layers and buzzing gone. I still get an occasional rattle on rough roads. I have a book of matches stuffed in the lid as a shim. I never put anything in there or open it so I'm considering taking the hinges out and just using RTV and gluing the door back on and forget it.
Old Dec 27, 2011 | 04:45 PM
Porthos's Avatar
Porthos
I use mine becuase that is where my IPOD spends most of its time. Once I can sit down and look at it to find out why it is rattling I will fix it. It started buzzing when I replaced the clear plastic gauge faces. I had to take the dash apart to replace the damn things and dropped a screw in the back of the compartment and well had to take it out and that is when it started rattling.
Old Jan 5, 2012 | 03:27 PM
Dr.Fox's Avatar
Dr.Fox
After searching far and wide for the rattle that I have, and that bugs me the most, I think I've found it...the secret compartment.
It starts around 1500 rpm and ends around 2000-ish, mostly in cold weather. If i make a fist and give the top of the dash a bump, I can recreate the buzz every time. Is this what you guys are talking about? Because it's not coming from the door to the compartment, rather the bin portion itself (I think).
Thoughts?
Old Jan 6, 2012 | 02:12 PM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy)
Have you checked to see if the a/c vent is rubbing the door panel? I reached over once when mine was buzzing and pushed my hand in there a bit (basically gently pulling the a/c vent exterior a bit) and it went away. A small shot of that felt between the two seems to resolve, and I've seen this on many others.
Old Dec 23, 2016 | 05:59 PM
Johnna's Avatar
Johnna
Mine too. I think I fixed it. (Fingers crossed). I separated the lid from the door mechanism added some pieces of double stick trim tape and reassembled the lid. My first test ride was blessedly rattle free! Double stick trim tape between lid and door mechanism.
ToyCar
Nov 19, 2023 05:20 AM
BXR
Mar 21, 2016 05:06 PM
rob&JCW
Sep 10, 2015 12:06 PM
Dieseldoctor
R55 :: Clubman Talk (2008+)
Sep 9, 2015 01:17 PM
Sep 8, 2015 11:37 AM
