Interior/Exterior Interior/Exterior painting
Old Dec 16, 2011 | 06:37 PM
H. STGLTZ's Avatar
H. STGLTZ
Ok so have two quick one I think.
1. The headlamp shroud, the only way to get it out is to peel the lens away from the housing to get to it?
2. The little barriers between the toggle switches, complicated to remove?
Old Dec 16, 2011 | 07:00 PM
Bubble and Squeak's Avatar
Bubble and Squeak
Ahhh Don't remove those barriers. Those are part of the "character" of the car. They original design (form the classic Mini's) if I recall was so that your finger did not slip from one to the other as you were on a rally track. They are part of the car like your dinner plate speedo is.
Just my 2 cents, I suspect there is a pair of holes between each switch if you remove them...
I also suspect your car will stop working, and may vanish into thin air.
Old Dec 16, 2011 | 07:37 PM
H. STGLTZ's Avatar
H. STGLTZ
Hahaha, I'm not removing them for good. I wanna paint them.
Old Dec 19, 2011 | 12:23 PM
schatzy62's Avatar
schatzy62
Yes and i believe you are talking about doing what is called a Joey Mod.
The panel will just pull off with a good pull but i am not sure if the chrome barriers are screwed on or are molded as part of it.
Old Dec 19, 2011 | 12:39 PM
H. STGLTZ's Avatar
H. STGLTZ
Yes the joey mod! Was hoping go avoid the oven lol
Thank you sir!
Old Dec 19, 2011 | 12:47 PM
schatzy62's Avatar
schatzy62
Thank you sir!
Here are a couple of threads on the process.
https://www.northamericanmotoring.co...t-halogen.html
https://www.northamericanmotoring.co...od-how-to.html
https://www.northamericanmotoring.co...tructions.html
Old Dec 19, 2011 | 12:50 PM
schatzy62's Avatar
schatzy62
Here is a thread on the switch panel.
https://www.northamericanmotoring.co...gle-cover.html
bahman
Feb 14, 2016 10:29 AM
jeri534
Nov 6, 2015 01:40 PM
vulkandino
Oct 31, 2015 08:29 PM
BackcountrySkier13_inAZ
Oct 14, 2015 06:00 PM
M7Speed
Oct 1, 2015 07:05 AM
