Interior/Exterior Interior/Exterior painting
Ok so have two quick one I think.
1. The headlamp shroud, the only way to get it out is to peel the lens away from the housing to get to it?
2. The little barriers between the toggle switches, complicated to remove?
Just my 2 cents, I suspect there is a pair of holes between each switch if you remove them...
I also suspect your car will stop working, and may vanish into thin air.
The panel will just pull off with a good pull but i am not sure if the chrome barriers are screwed on or are molded as part of it.
Here are a couple of threads on the process.
https://www.northamericanmotoring.co...t-halogen.html
https://www.northamericanmotoring.co...od-how-to.html
https://www.northamericanmotoring.co...tructions.html
vulkandino
Oct 31, 2015 08:29 PM
BackcountrySkier13_inAZ
Oct 14, 2015 06:00 PM
