R50/53 Wrong antifreeze; mobil 1
Old Dec 11, 2011 | 03:01 PM
micromini234's Avatar
micromini234
Well I noticed my antifreeze was almost all gone, so I put mobil 1 anti freeze and coolant in, and now that im reading up it seems like this was a bad move on my part, can anyone tell me if this will create a problem?
Old Dec 11, 2011 | 03:17 PM
ZippyNH's Avatar
ZippyNH
I know mobil1 made oil....
Have not seen a branded coolant in that name...
What color is it?
Red, orange, yellow, green, or blue?
the chemical reaction takes a bit...even if you used orange/red, and it turns to jello (thats what happens when it mixes, a few ounces should make it easy to flush...
I bet you let the coolant run so low, it now has an air bubble in the system that meeds to be bleed out...and imo drop the lower radiator hose+heater hose, and flush it....then use the coolant of your choice. Bmw/mini blue is a bit of a hybird...and it is unlikly mobil1 stuff is 100% compatible, even if it is a universal....
Old Dec 11, 2011 | 03:27 PM
micromini234
its a green color, but not thats it the reservoir it looks a bit blue, Ok thanks good to know! well im just wonder if its going to have any bad effects?
Old Dec 11, 2011 | 04:02 PM
abjb's Avatar
abjb
When you say “almost all gone” do you mean below the MIN mark on the expansion tank and you added a few ounces?
Or the tank was empty and you added a quart or more?
ab
Old Dec 11, 2011 | 04:15 PM
micromini234
like minimum level, almost gone. On on a side note the fluid in the expansion tank wasn't blue it was like clear or brown.. soo yeah..
Old Dec 11, 2011 | 04:28 PM
jcauseyfd's Avatar
jcauseyfd
The color doesn't matter. Different companies will make their coolants different colors. iirc, you need something that is safe for use in aluminum system? I think that mean phosphate and borate free? Don't really remember for sure - been a while since I researched.
If you are really convinced you have the wrong stuff in your MINI, then I'd flush it and put in new coolant. I don't think it is so critical you can't drive the MINI until you get it done. But probably the sooner the better.
Old Dec 11, 2011 | 05:02 PM
micromini234
[QUOTE=jcauseyfd;3413918]The color doesn't matter. Different companies will make their coolants different colors. iirc, you need something that is safe for use in aluminum system? I think that mean phosphate and borate free? Don't really remember for sure - been a while since I researched.
If you are really convinced you have the wrong stuff in your MINI, then I'd flush it and put in new coolant. I don't think it is so critical you can't drive the MINI until you get it done. But probably the sooner the better.[/QUOTE
Yeah thats where my research led, it also seems like your not suppose to put anything with phosphates, or nitrate, but that leads me to the question of dipotassium phosphate?, well I agree with you though and zippy, I dont wanna to take any chances so im gonna attempt to flush it thanks guys.
* Update on dipotassium phosphate isnt really harmful! if you ever find that in it. http://www.saturnfans.com/forums/showthread.php?t=53692
Old Dec 11, 2011 | 05:52 PM
Applesauce's Avatar
Applesauce
I don't think coolant should just "run low." It's a closed system. I can't really tell you if you're looking at problems because of the current mixture, but I can almost guarantee you have a (possibly problematic) coolant leak someplace.
Old Dec 11, 2011 | 06:06 PM
markjenn's Avatar
markjenn
It would help if you'd tell us precisely what you put in. AFAIK, Mobil One does not make a branded antifreeze.
Stock, the Mini comes with an ethylene glycol type AF, and if you are topping off, it is best to use a EG antifreeze. If you're flushing the system, you could go with one of the other types (e.g., organic acid aka Dexcool, or propylene glycol), although these new antifreeze types are somewhat controversial (not unlike synthetic oil).
As someone else said, you can't go on color anymore. You have to find out what your car has and find the right stuff on the shelf. Or just exactly what the mfg of the car recommends.
- Mark
Old Dec 11, 2011 | 06:22 PM
Evasive's Avatar
Evasive
Color doesn't matter so long as you're not mixing different colors. My suggestion would be to simply flush it and put one type of coolant in.
Old Dec 11, 2011 | 06:28 PM
micromini234
- Mark
Ok the brand is called Mobil Permazone? maybe its a rebrand; either way its said to be controversial so it must be new. I got it at the mobil, but yeah I think im just gonna go to the dealer and buy some oem stuff.
Old Dec 12, 2011 | 07:05 AM
cristo's Avatar
cristo
Alliance Member
http://www.matweb.com/search/datashe...5290be99a9e72d
Mobil Permazone Antifreeze and Coolant is a conventional green colored antifreeze containing inhibitors providing protection from freezing, overheating, rust and corrosion when used as recommended. Mobil Permazone Antifreeze and Coolant features a universal low silicate formula for use in all conventional automobiles and light duty trucks and protects all cooling system metal surfaces, including aluminum. When used in heavy-duty applications, the addition of a separate Supplemental Coolant Additive (SCA) is required.
Looks like it should be compatible with the oem antifreeze/coolant in small to moderate amounts - not like the VW/Audi orange stuff that gels when combined with conventional antifreeze/coolant
Old Dec 12, 2011 | 11:07 AM
markjenn's Avatar
markjenn
Permazone is a conventional EG antifreeze and should be completely compatible with what is standard on the Mini.
- Mark
vulkandino
Oct 31, 2015 08:29 PM
TunedGP
Oct 1, 2015 04:18 PM
simo711
Oct 1, 2015 05:36 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
TifosinDel
Sep 28, 2015 10:45 AM
